Just contacted the seller for the info. Will let you know soon
2009 Tiguan TDI and 2007 Passat TDI
Wheels are 18x8et43 most likely?
Your passat is 17x7.5et45 or something.
Which is basically the same
They should fit - about the only ones that are a bit weird are the A5 because the offset is ~ET27
I did some research and the passat is
PCD Center bore Offset
5x112 57.1 45
The Audi is
5x112 57.1 42
Offset is a bit different. Wonder if this will cause any issue
The offset changes dynamically with the width. Suggest you bung your diameter, width & offsets into a wheel calculator & you'll see what I mean
1010TIRES.COM - Wheel Offset Calculator
Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Thanks brad
Look on the back of the new wheels, write down the specs.
Look on the back of your stock wheels, write down specs
My passat is 5x112 ET47
The Audi is 5x112 ET47
Perfect fit
