Since the heavy nose weight causes understeer on turn in (even with a Haldex) you should be putting the wider rims on the front, not the rear. Then a Haldex needn't be so biased to the rear to get neutral handling for other cornering phases.
But that's for performance. It would probably look a bit odd so no go for pose (which is what 19" wheels are about, anyway).
- You may not post replies
- You may not edit your posts
Forum Rules
