For the record anyone not in tasmania and over fifty check out the euro scene for wide wheels. ta
Like a 4wdOriginally Posted by evorobin
first thing i saw coming into the austrian alps was a mk2 slammed on dinky wide 14s its looked great and it was for sale![]()
You set the suspension up Ed. You must like 4wds?!?Originally Posted by Golfwise
I am planning on lowering it but it's not a priority......
At least my car isn't running on chopped springs!!
Aren't they illegal?
HELP IS AT HAND!!!
Say you were running std vw fit wheels 15 x 6 et35 and wanted 15 x 7 et28 the difference would be
Inner Clearance: -6mm
Outer Position (position of the outside edge of the wheel) +20mm
So we can gather that if a protrusion of 20 mm is still legal it is ok to order said wheels. If not start fabricating!
I do recall I cut those springs down, look for the oxy marks on them.Originally Posted by delux
the new VW Transporter steelies kind of look like ATS Cups.. have you guys seen them?
My you are a bit dodgy aren't you?!?!Originally Posted by Golfwise
Lucky they're going then eh?
Cut springs are fine if you know what you're doing!
My point exactly!
