Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 53
Thread: ATS Cups on mk1 GTI
  1. #41
    Golfwise Guest
    Quote Originally Posted by evorobin
    There were some pics of Jeremy's mk1 with the RS I sold him on the old forum. The rears were 15x7 et15 and front 15x6.5 et25. Looks great!
    Like a 4wd
  2. #42
    For the record anyone not in tasmania and over fifty check out the euro scene for wide wheels. ta
  3. #43
    first thing i saw coming into the austrian alps was a mk2 slammed on dinky wide 14s its looked great and it was for sale
  4. #44
    Feb 2006
    Hobart TAS
    Quote Originally Posted by Golfwise
    Like a 4wd
    You set the suspension up Ed. You must like 4wds?!?
    I am planning on lowering it but it's not a priority......
    At least my car isn't running on chopped springs!!
    Aren't they illegal?
  5. #45
    HELP IS AT HAND!!!
    Say you were running std vw fit wheels 15 x 6 et35 and wanted 15 x 7 et28 the difference would be
    Inner Clearance: -6mm
    Outer Position (position of the outside edge of the wheel) +20mm
    So we can gather that if a protrusion of 20 mm is still legal it is ok to order said wheels. If not start fabricating!
  6. #46
    Golfwise Guest
    Quote Originally Posted by delux
    I do recall I cut those springs down, look for the oxy marks on them.
  7. #47
    the new VW Transporter steelies kind of look like ATS Cups.. have you guys seen them?
  8. #48
    Feb 2006
    Hobart TAS
    My you are a bit dodgy aren't you?!?!
    Lucky they're going then eh?
  9. #49
    Cut springs are fine if you know what you're doing!
  10. #50
    Feb 2006
    Hobart TAS
    My point exactly!
Similar Threads
  1. the swallow tail project has begun.......
    By alex g in forum Mk1 Golf
    Last Post: 06-06-2022, 10:34 PM
