Any negative effects of increasing scrub radius?
Hi all,
Apologies if this has been addressed previously, had a search but couldn't find the answer.
I was after advice/opinion on whether an increase of ~5mm of scrub radius will have a noticeable effect on my soon to be delivered Mk7.5 Golf R?
I'm looking to change the stock 19x8 ET50 wheels to a set of 19x8.5's with ET45 (transferring the same 235/35R19 rubber). From my research I think they should fit fine but will increase the scrub radius by ~5mm. I have tried to get my head around the effect of making the scrub radius more positive vs more negative but as I am hoping to get the tires transferred onto the new rims won't be able to run them back to back to see.
Anyone have any thoughts on whether there would be any noticeable difference at this level?
Cheers!
Mk7.5 Golf R Grid Manual, 273Kw & 500Nm atw on 🌽
Galano Stage 2 E85 flex tune, IE IC, IE DP, NPC SMF Clutch, HPFP, LPFP, injectors, Forge inlet pipe, BMS turbo inlet, Superpro FSB/RSB, 034 dogbone mount inserts, T3 4000 slotted rotors, ATE ceramic pads
