Originally Posted by
vwpolo
Thanks tigger73 but the link goes to lowered springs , i want the raised ones i live in regional nsw and need the height
I didn't realise Eibach made such a thing.
/searches catalogue... partno E30-85-020-02-22 ???? I think you'll find they are "buy-in" only.
H&R do a lift spring or
you could fit Spaccer spring spacers.
KYB do a heavy duty rear but I think it's OEM height & an increased spring rate.
You could also get custom springs made locally. K-Mac will do it however you want.
NB: if you go too high at the front (50mm +) the dampers will top out on sag. You'll also have problems getting enough negative camber. You can probably fix it with Audi TT control arms but be aware you are venturing onto the slippery slope of mods
