Results 1 to 10 of 12
Thread: Another track wheel thread... is 7" enough?
    Apr 2011
    Ipswich, QLD
    I need to get some lighter 17" wheels that I can wrap in semi slicks and may have some but I am not sure if they are wide enough. I was looking at 225/45/17 RE55S for the tires but bridgestone recommend 8" rims to put them on. In experienced peoples opinions are 215's going to offer enough traction for serious cornering?
    The bora is a very heavy car and for the moment at least weight reduction will be limited to the rear seat backs, spare tire etc so traction is very important but also brings into mind load ratings for semi slicks. Most seem to be lower than street tires, if 92 is the stock rating do I need that from racing rubber?
    2003 Bora 4Motion
    Boronia VIC
    Why not just run the stock size of tyre for that car in a semi slick?
    The semi slicks are really much better than a street tyre.
    If you go too wide you might not be able to get them up to temp.
    I carry a lot more corner speed than a lot of more powerful cars on 10" rims and I'm only racing on 185/60/14
    Just some food for thought, you don't have to go silly on the width.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Apr 2011
    Ipswich, QLD
    Thanks for the advice, thing is the 225/45/17 is the stock tire size for the 03 4motion. The wheels I am looking at are for sale here but are only 7" wide, I was mistaken about the rim size that bridgestone recommend, they say 7.5" rims not 8". So I guess the best question is thus...
    Will a 225 semi slick go on a 7" rim or would I have to go down to 215's?
    2003 Bora 4Motion
    Boronia VIC
    There's a handy tyre (tire) size calculator at 1010tires.
    Tire Size Calculator - tire & wheel plus sizing
    According to that the acceptable range for a 225 is 7" - 8.5"
    A 215 is 7"-8"
    It's a very useful tool and will even tell you differences in speedo readings etc.
    7? MK1 Caddy
    12 Amarok
    Jul 2011
    7" rim is ok for 225. I have used 225/50/15 on 7 X 15 and 225/50/16 on 7 X 16 for Toyo R888's for the track and is within the range that
    Toyo recommends. Peter gives good advice and is right about not getting enough temperature into the tyre is you go too wide.
    Also the smaller rim is lighter.
    Apr 2011
    Ipswich, QLD
    Seems my googlefoo was weak earlier and your advice is well founded and backed up. Think I will stick with 225's so just need to get the rims.
    Thanks very much for the help
    2003 Bora 4Motion
    bora comes stock with a 225/45/17 on a 17x7
    Boronia VIC
    Good point.
    Mine's got the 16's on it. Never bothered looking into the bigger diameters as I do a lot of towing into paddocks and dodgy carparks with the race car on the tandem.
    7? MK1 Caddy
    12 Amarok
    might be a retarded comment, but being a semi slick does it make a difference? (are they more solid/square compared to normal road tyres)
    Boronia VIC
    Yep, much tougher than street tyres, the Toyos have steel belts in the sidewalls and much less sidewall flex than a street tyre.
    The compund is a lot softer too.
    7? MK1 Caddy
    12 Amarok
