What do they look like?
It might be best to contact the manufacturer about the best way to torque them down.
My wheel stud conversion kit finally arrived from Motorsport hardware. When fitting the wheel studs (M14) is there a recommended torque spec for seating? Do I need a dab of loctite too?
'07 Transporter 1.9 TDI
'01 Beetle 2.0
long nosed with allen key fitment. A shoulder between the seated part and the actual stud that the rim fits on.
82mm Black Bullet Nose Race Stud Kit 14x1.5 - Motorsport Hardware
looks like other guys are dabbing loctite and torquing it up to 50ft-lbs
cw.mkv.gti.034ms,s2+
50ft/lb is only 68Nm. The wheel bolts are usually 120Nm aren't they? I'd go at least to that with a dab of loktite.
i just figured it came down to the mating surface, the wheel bolts have a much larger area against the wheel lines than just the stud going into the hub
Golfs 120Nm - which isn't very tight.
ecs' kit seems to suggest threadlocker + 15nm is enough
