Results 1 to 10 of 10
Thread: Advice for cleanining/polishing/painting used alloys
    Mar 2006
    Canberra
    Can anyone point in the right direction to start with cleaning polishing or maybe respraying 2nd alloy wheels. Thanks in advance James
    Old Skool Passat Power Rules!!!
    1974 Passat LS with a SEAT 1.8, 32/36 Weber, full performance exhaust and a K&N filter. 80kw at the wheels??
    Jul 2005
    Melbourne, Williamstown
    Depends how easy or difficult you want to make it for yourself. I've done something like this before and it was a bit of a pain.
    The quickest way to get them stripped back without taking the tyres off the rim in my oppinion is with paint stripper. You can then polish and sand the rims or how much ever you want with "wet and dry" and then something like "autosol" metal polish. Or you could use a buffing wheel in a power drill with the buffing compound or something like that to get them shiny. Then spraying them is the easy part, after you tape up the tyres if they're still on the rims.
    Not saying this is how you should do it, just how I did it.
    Either way you'll need a lot of elbow grease. Very satisfying though.
    mk2 GTi 16v
    Corrado G60
    Mar 2006
    Canberra
    Thanks for that, if they look as good as your,s do in the pictures it will be worth it.
    Thanks
    James
    Feb 2006
    Hobart TAS
    Just take your time and it's all possible. (with alot of elbow grease!)
    Are they off a 924? Nice.
    Mar 2006
    Canberra
    I don't think so as the logo is not Porsche, they well maybe an after market job, I'll find out off the seller. Can't wait to get the Passat hooning 'round the corners on some sportier wheels and rubber.
    Golfwise Guest
    924 ? bolt pattern is nothing like a Passat or a Golf.
    Mar 2006
    Canberra
    They fit perfectly even over the floating disc.
    Camden, Sydney
    Chrome spray makes em shine in the dark. Get it clean underneath and it wont come off.
    I`d say they were Honda rims. But thats ok
    Feb 2006
    Hobart TAS
    wheel adapters? I've seen Fuchs on golfs and they are 5/130.
    They are an identical style to late 924 Turbo rims. Could be replicas I guess. Nice anyway.
    Feb 2006
    Hobart TAS
    You could paint the centres black and then polish the outer lip. Would help with hiding brake dust too!
Similar Threads
  1. Steelies v Alloys
    By vee_dub in forum Wheels & Suspension
    Last Post: 29-05-2006, 07:39 AM
  2. 1974 Passat Advice
    By vinderliker in forum Passat (B1, B2 & B3)
    Last Post: 06-03-2006, 10:46 AM
  3. jacking up a mk 3 - advice
    By golfvr6 in forum Mk3 Golf & Vento
    Last Post: 13-02-2006, 09:22 PM
  4. ALLOYS ON T4
    By DOUBLECAB in forum Wheels & Suspension
    Last Post: 19-01-2006, 02:23 PM
