![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
The_Hawk
From what I understand, wobble bolts are designed to allow the threaded bolt to sit off centre to the floating rounded seat/washer since it otherwise wouldn't be centred and wouldn't be holding on correctly.
Given we are talking an offset difference of 2.3mm or 1.15mm off centre per bolt that's getting close to the tolerances the wheels are likely built to so you are correct that they are probably very close to OK even with standard bolts. The wobble part making things sit that much more cleanly and even more likely to work perfectly. As long as you are running hub centric rings everything *should* be neatly aligned.
But like I said, it's not something I would personally do or recommend to others. What special must have wheels are you looking at that happen to be 114.3 ??
