Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: 215/35/18 or 225/40/18 on a 9.5 Inch Rim - Appearance Only
    brisbane
    Hi guys i'm after your opinion;
    Which LOOKS best a 215/35/18 or 225/40/18 tyre on a 9.5 inch rim. I know the stretch thing is an age old debate and i know i'm contradicting myself saying i like my performance but i also like the looks too.
    In this case i'm only after your opinions on which looks best. I tried some wheels on last week and i can't decide on the tyre size so hope you can help. i think i'm leaning towards the 225/40/18 as the 35 just looks like a too small wall size.
    you decide;
    unfortunately i didn't get chance to take any photos of the 225's on the car;
    still not 100% on which wheels to choose either
    i'd appreciate your feedback but lets not have the stretch debate again,
    May 2011
    Albury, NSW
    I'd say in between the two - I'm all for stretch, but I think the profile on the 35 is just too low!
    And if you haven't decided on wheels then you need Bentley's or Helios or something...those wheels look ricey as!
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Jun 2009
    Melbourne, VIC
    Depends how low you are gonna go. I'd try to match rolling diameter with stock so your speedo stays as accurate as possible. Only stretch if you have to fit it under guards.
    I personally like sidewall as extremely low profile tyres remind me of 20s on Commodores.
    VW Bora V6 4motion
    Jan 2009
    If roadworthiness and performance matters, then 225/40 R18 92Y XL tyres on 8.0 J x 18 wheels.
    Otherwise, go with 215/35 R18 tyres if your car is mainly a cruiser. Should go down pretty well with the stretch brigade.
    Oct 2012
    based on the wheels only photo comparison I liked the 215/35...
    until I saw them on the car, imo just doesn't quite look right, too small rolling diameter.
    my 2c worth
    A4 '97 1.8TQ |GT2871r|QMS E85 tune|
    A4 '98 Avant 1.8TQ|Daily
    Previous: A4 '97 1.8T | A4 '96 1.8T | A4 '95 2.6
    Sep 2006
    West Sydney
    Quote Originally Posted by guile View Post
    Since you were able to test fit the wheels and tyres together, it'll be easy for you to see what tyre size you need to go. If you can still run 225/40 without rubbing, then go for that. Tyre stretching isn't about going as mental as you can; as long as you can clear your guards/suspension, then that's all you really need to run. Going further means you're gonna have to run lower to achieve the look you want. The pic of your car with 215/35R18 tyres on, is that the height you'll be running at all the time? Then I would suggest the 225/40 so it fills out the wheel gap.
    Also, there's 215/40R18 and 225/35R18 available that you could run. I personally have 18x10s on the rear of my 8L with 215/40R18. I decided to go for that tyre cos I needed enough stretch to achieve this:
    Otherwise I would've went for 225/35 or 235/35.
    Oct 2010
    Melbourne, VIC
    What about legality? I seriously doubt the 215/35R18 is rated high enough for your car (the ones I found only had an 84 load rating)
    Resident grumpy old fart
    Why those two sizes, if your car isn't slammed stick to a 40 profile otherwise u will have awkward wheel gap.
    Don't stretch tyres for the sake of it, do it to suit the fitment on your car.
    Test fit the wheels and decide what you need for clearance.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    May 2011
    Albury, NSW
    ^what Dyl said!
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Sep 2006
    West Sydney
    Quote Originally Posted by kaanage View Post
    Legality went out the window with 9.5" wide wheels.
