Just mind out there's a different offset used on Scirocco to Golf R if you're going for a set of second-hand OEM rims.
Hi All,
As the title says, I need to know if 19 inch Tallies are going to fit on my GT Sport.
I realise they will fit, but will they rub? am assuming I'd need to run 225s rather than 235 ? any other issues with width? legal?
I've seen some photos around the interwebs, but don't know anyone with these on a MkV
thanks
If they are from a GOLF R they will be fine.
GOLF | GIAC | CTS K04 | 215.9kws atw
225/35s may not have the correct load rating.
Both rococo and golf wheels should fit,rococo ones just being 10mm or so more filling in regards to offset
Also consider what height you're going to be running at. As pointed out I don't think you'll get a legal load rating with 225's forcing you to go to 235's and in which case you'll most likely get rubbing issues if you're running less height than stock. Pretty sure the Golf R's wheels are 19x8 with an ET of 50 so these with 235's would end up sticking out 6mm more than mine do ( I have 18x7.5, ET 45 and 225's ) and I've got some pretty bad rubbing issues at 50mm drop- at 55mm I can't even turn the wheels.
2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
