Just because it's you, I'm prepared to swap my 17's.......
I think 17's will look very small and disproportionate on the R... I know what you are saying about NQ roads, having just moved from Townsville, but I was running 18's with 35 profile rubber on them, and didn't have any real problems on my Polo GTI....
VW's tyre/rim sizing is a mystery to me as they don't seem to always choose the closest match for the different rim diameters.
The "standard" fitment for the R is the 225/40R18 which matches well with the 225/45R17 (and 205/50R17 but I can't see you fitting these). Then again, the 235/35R19 is the closest match in the 19" to the "standard" fitment.
Is there odometer adjustment in VCDS for this?
It all depends on what is more important - what other people think or what you think.
Performance nearly always gets the nod over fashion for me.
225/35 R19 does indeed more closely match 225/40 R18 - however, with a load index of either 84 or 88 XL, the load capacity of any 225/39 R19 tyre is insufficient for the Golf, hence why I suspect VW went for the next size up.
Choosing between an incorrect speedo (which could be fixed via software) or potential for overloading the tyres (potential safety/legal ramifications)? VW probably went for the former rather than the latter.
Don't know, but I wouldn't be surprised if there were such an option, as I imagine any system dependent on a pre-specified rolling circumference (ABS, ESP, etc) would need to be configured according to pre-specified tyre fitments.
Luckily, having the vehicle preconfigured for 235/35 R19 tyres means the OP would do well from fitting 235/45 R17 or 235/40 R18 tyres.
In my opinion (like the OP needs any more) I reckon 235/40 R18 95Y XL tyres on 8.0 J 18 wheels would provide the best compromise between ride, handling, grip, aesthetics and practicality.
It will make your speedo more accurate as they do read higher from factory, but in your MFD there is a kmh adjustment to counteract aforementioned winter setup.
without knowing the exact circumference of each (use a wheel and tyre calculator for specifics) but you can +/- to adjust on our MFD I'm pretty sure.
I know the speedo can be adjusted relative to the odometer but can the odometer (being the base distance measurement) be adjusted as well?
To expand on what I said earlier, fitting smaller tyres will make the speedo read faster, not slower.
The speedometer is supposed to be set up in such a way that it shall never underestimate the vehicle's speed. Reducing the rolling circumference exacerbates that effect, and vice versa.
Rolling circumference of various tyre sizes (from smallest to largest):
225/45 R17 = 1934 mm
225/40 R18 = 1943 mm
205/50 R17 = 1946 mm
235/45 R17 = 1964 mm
235/40 R18 = 1967 mm
235/35 R19 = 1973 mm
