View Poll Results: What size should I get ?
Voters
2. You may not vote on this poll
  • 17 inch
    1 50.00%
  • 18 inch
    1 50.00%
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 17 or 18 inch for my Jetta
    Aug 2015
    Nsw
    18s and springs 80 % comfort
    2015 1.4 118 TSI Manual Jetta - APR CAI - GFB Diverter Valve - WORK SEEKER SX 18X8.5+35 - Muffler Delete - BC Coilovers - RCD 510
    Oct 2010
    Melbourne, VIC
    80% relative to what??
    To the OP, 18" rims+lowering springs would seem to be what you're after
    Resident grumpy old fart
    Jun 2015
    Liverpool, NSW
    So I went to buy the wheels but they didn't have any stock (of the ones i wanted), this is all they have :
    I'm going to have to shop around.
    Current 2023 T-Roc R-Line 140TSI | Past 2015 Jetta Trendline 118TSI
    Jun 2015
    Liverpool, NSW
    but I have definitely decided to get 18's
    Apr 2009
    Northern Tasmania
    I had the same question recently and have bought 225/40x18 wheels. Should be sticking them on my (currently 16") standard height Octavia soon (will post pics in my thread - below). I am worried that, as Brad says, they will look lost because the car is not lowered. Also that they may be too uncomfortable. There is also quite an increase in unsprung weight with larger wheels.
    Which wheels - give me an opinion
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
    Erskineville, NSW
    Quote Originally Posted by wfdTamar View Post
    You are on 8" rim width now aren't you? When the 225/40r18 (25.1" diameter) wear out, get some 235/40r18 (25.4") - they'll fit an 8" rim. You might even get away with 245/40r18 (25.7") but it would depend on the wheel offset.
    I ran 25.7" diameter on Eibach Proline without any issues.
    I also ran 25.9" but there was minor scraperage up front if the suspension compressed when cornering. It wouldn't have been an issue at standard height & if I had an Octavia Scout (I know you have the standard height stealth AWD - just sayin') it would be my diameter of choice.
    May 2007
    Quote Originally Posted by jake85 View Post
    Where did you go for these (in the picture)?
    I like the wheels top shelf, in the middle!
    Apr 2009
    Northern Tasmania
    Got mine on - pictures here
