15s are ideal on a Mk1.
There are lots of Honda or aftermarket cheap wheels around in a 15.
Try the bay of E.
whats better ? have 205/60r13's
but good grippy tyres are getting
hard to get eg: best i found were
brige's gIII's at $140
I can get 195/50r15 eagle f1 gds3's for $115
but then have to find a cheap rim that
I like . please help sway my decision
what is the ideal offset??
my 13's are different front to back.
back has more
Try the bay of E.
what offset???
Speaking from alot of experience with tyres & what not in general.
Stay away from the eagle f1's. They're noisey & grind like absolute hell under hard cornering & braking. Even under light braking they grind. They also like to tram track.
Currently I've got on my Mk1 15x7 ET25 with 195/50 R15 Michelin Pilot Preceda PP2 & yes they are expensive, but they are the best tyre I've had so far. (Except for some Dunlop W10's I had along time ago.)
You can push them to the absolute limits. Can't wait to put them to the track.
I wouldn't go any less than ET30 on a mk1 with 15" rims. You'll still have to roll the front & rear arches though.
Regarding the ET, yes I know that I have ET25 on my mk1 & they do scrub lightly every now & then (I've rolled the front & rear arches & cut out the wheel arch trims!), but they are the only wheel I have at the moment & they also give the car a low & fat stance!
I've tried nearly everything from ET45 to ET25 & I reckon if you stay over ET30 you'll be fine with 15" even if you belly ache it!
My two bob!
Toyo TPG/TR1 in 195/50/15. You don't need a wider tyre on a mk1. Should cost $115 for TPG or around $150 for TR1
Look in the wheels andd tyres section for wheels that fit and offset info.
As robyn say 195/50/15 is perfect on a Mk1 and Tyres are cheap.
thanks everybody
looks like I'll be looking for
15's soon then
