Results 1 to 7 of 7
Thread: 15?
    May 2006
    Maryborough Vic
    Question 15?
    whats better ? have 205/60r13's
    but good grippy tyres are getting
    hard to get eg: best i found were
    brige's gIII's at $140
    I can get 195/50r15 eagle f1 gds3's for $115
    but then have to find a cheap rim that
    I like . please help sway my decision
    what is the ideal offset??
    my 13's are different front to back.
    back has more
    Camden, Sydney
    15s are ideal on a Mk1.
    There are lots of Honda or aftermarket cheap wheels around in a 15.
    Try the bay of E.
    May 2006
    Maryborough Vic
    Question
    what offset???
    Speaking from alot of experience with tyres & what not in general.
    Stay away from the eagle f1's. They're noisey & grind like absolute hell under hard cornering & braking. Even under light braking they grind. They also like to tram track.
    Currently I've got on my Mk1 15x7 ET25 with 195/50 R15 Michelin Pilot Preceda PP2 & yes they are expensive, but they are the best tyre I've had so far. (Except for some Dunlop W10's I had along time ago.)
    You can push them to the absolute limits. Can't wait to put them to the track.
    I wouldn't go any less than ET30 on a mk1 with 15" rims. You'll still have to roll the front & rear arches though.
    Regarding the ET, yes I know that I have ET25 on my mk1 & they do scrub lightly every now & then (I've rolled the front & rear arches & cut out the wheel arch trims!), but they are the only wheel I have at the moment & they also give the car a low & fat stance!
    I've tried nearly everything from ET45 to ET25 & I reckon if you stay over ET30 you'll be fine with 15" even if you belly ache it!
    My two bob!
    Toyo TPG/TR1 in 195/50/15. You don't need a wider tyre on a mk1. Should cost $115 for TPG or around $150 for TR1
    Camden, Sydney
    Look in the wheels andd tyres section for wheels that fit and offset info.
    As robyn say 195/50/15 is perfect on a Mk1 and Tyres are cheap.
    May 2006
    Maryborough Vic
    Talking
    thanks everybody
    looks like I'll be looking for
    15's soon then
