Page 8 of 17 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 162
Thread: White Mk4 GTI
  1. #71
    Melbourne, VIC
    Here's a pic of the spacer and washers
    The daily
    White 2001 Mk4 GTI
    GIAC stage 1 - ECS stage 1 clutch & 14lbs Flywheel - 42Draft/Remus Exhaust - APR R1 dv - N75J - K&N
  2. #72
    Melbourne, VIC
    Wanted to clean up the engine bay some more so gave what I had sprayed another coat and added in the airbox while I have the pod in.
    This is the first coat on the airbox.
    The daily
    White 2001 Mk4 GTI
  3. #73
    Melbourne, VIC
    Wanted to drop the rear another 10mm for dovw but i don't think i will have time cos i need to remove the lower locking collars, and just don't have the tools or know how to do it at home
    Lower grills and engine covers are all ready painted and ready to go
    I also have a red tip and induction hoses coming but again most likely not before the weekend
    The daily
    White 2001 Mk4 GTI
  4. #74
    Apr 2010
    coogee NSW
    Quote Originally Posted by theOctopus View Post
    That can't be safe..
    R36 Twin Turbo Golf 650hp 0-100 3.1sec 11.106@125mph.
  5. #75
    Aug 2005
    Quote Originally Posted by AP View Post
    You're right. That is an absolute disaster waiting to happen. The wheel mounting surface must be dead flat to ensure consistent torque of the wheel bolts. Standard washers will deviate in diameter by up to 1mm and this will only be made worse by using varying amounts of epoxy to secure them.
    There is very real potential for the bolts to work their way loose with a setup like this!! Scary
  6. #76
    Melbourne, VIC
    Quote Originally Posted by Valver. View Post
    Thanks for the advice ill take em off and try and work out another way to remove the gap between the spacer and the wheel or worse case get another set that fits better
    The daily
    White 2001 Mk4 GTI
  7. #77
    Point Cook, Vic
    take your wheels and spacers to Ajax in Moorabbin.
    They can machine the centre bore of the wheel to mate to the spacer properly. Shouldnt cost much more than $50/wheel
    FOLLOW US ON FACEBOOK
  8. #78
    Melbourne, VIC
    Cool thanks Tim, doing that sounds a lot better than getting a new set
    The daily
    White 2001 Mk4 GTI
  9. #79
    Melbourne, VIC
    Got this today from the UK, now waiting on induction pipes and ill be ready to get them on the car.
    The daily
    White 2001 Mk4 GTI
  10. #80
    melbourne
    lookin good, jake!
    like craig said at dovw - VERY clean mk4. a bit of a sleeper, too, which is always a good thing!
