Wanted to clean up the engine bay some more so gave what I had sprayed another coat and added in the airbox while I have the pod in.
This is the first coat on the airbox.
Here's a pic of the spacer and washers
The daily
White 2001 Mk4 GTI
GIAC stage 1 - ECS stage 1 clutch & 14lbs Flywheel - 42Draft/Remus Exhaust - APR R1 dv - N75J - K&N
The daily
White 2001 Mk4 GTI
Wanted to drop the rear another 10mm for dovw but i don't think i will have time cos i need to remove the lower locking collars, and just don't have the tools or know how to do it at home
Lower grills and engine covers are all ready painted and ready to go
I also have a red tip and induction hoses coming but again most likely not before the weekend![]()
The daily
White 2001 Mk4 GTI
You're right. That is an absolute disaster waiting to happen. The wheel mounting surface must be dead flat to ensure consistent torque of the wheel bolts. Standard washers will deviate in diameter by up to 1mm and this will only be made worse by using varying amounts of epoxy to secure them.
There is very real potential for the bolts to work their way loose with a setup like this!! Scary![]()
The daily
White 2001 Mk4 GTI
take your wheels and spacers to Ajax in Moorabbin.
They can machine the centre bore of the wheel to mate to the spacer properly. Shouldnt cost much more than $50/wheel
Cool thanks Tim, doing that sounds a lot better than getting a new set![]()
The daily
White 2001 Mk4 GTI
Got this today from the UK, now waiting on induction pipes and ill be ready to get them on the car.
The daily
White 2001 Mk4 GTI
lookin good, jake!
like craig said at dovw - VERY clean mk4. a bit of a sleeper, too, which is always a good thing!
