Page 6 of 17 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 162
Thread: White Mk4 GTI
  1. #51
    Looking good!
    Just wondering how high you have the rear and front wound up? and how far the front adjuster is from hitting the top of the tyre?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  2. #52
    Melbourne, VIC
    Not to sure what you mean by touching the tyre, if i know more of what your asking i can let you know.
    In terms of what I've got left to move i have it at the lowest at the rear but can remove the lower locking coller and can get another 8 to 10 mm, at the front i can get another 18 mm lower.
    Do i need to go lower
    The daily
    White 2001 Mk4 GTI
    GIAC stage 1 - ECS stage 1 clutch & 14lbs Flywheel - 42Draft/Remus Exhaust - APR R1 dv - N75J - K&N
  3. #53
    if you look at your car from side on, is the adjuster at the front above the tyre, if so by how much...?
    There is always room for more lows haha. but its sitting nice as is, nice even tyre to wheel spacing all round.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  4. #54
    Melbourne, VIC
    Ok I get what you mean, I'll have a look after work and let you know.
    I want to get some spacers for the rear to pull them out a bit more to make them sit like the front in relation to the guards, Where is the best place to get them.
    Also I'm going to de-badge the rear, hopefully it will be in a better state for the Day of the Volkswagen, not sure if its worthy of the show and shine yet, so might just do parking.
    The daily
    White 2001 Mk4 GTI
  5. #55
    Quote Originally Posted by theOctopus View Post
    Awesome! thanks.
    ECS maybe? get a kit with extended bolts etc.
    Car looks very show worthy. Just enter it! my car is always dirty and covered in scratches and its there everytime. Think you have to enter the show and shine to park in the grounds...?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  6. #56
    Melbourne, VIC
    Hi Dylan is this what you mean?
    Looks like the top of the tyre is level with the top of the lower locking collar.
    The daily
    White 2001 Mk4 GTI
  7. #57
    Yep. exactly.
    Have you got both or just one spring in the front.
    I'm trying to find a coilover that will go lower without the adjuster wound down as far, reason for all my silly questions.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  8. #58
    Melbourne, VIC
    Give me a bit ill jack it up and check im not to sure, ill take a pic.
    The daily
    White 2001 Mk4 GTI
  9. #59
    Melbourne, VIC
    Single spring
    So are you wanting a shorter spring so the collar sits higher?
    The daily
    White 2001 Mk4 GTI
  10. #60
    Melbourne, VIC
    Dubway
    The daily
    White 2001 Mk4 GTI
