Yep. exactly.
Have you got both or just one spring in the front.
I'm trying to find a coilover that will go lower without the adjuster wound down as far, reason for all my silly questions.
Yep. exactly.
Give me a bit ill jack it up and check im not to sure, ill take a pic.
The daily
White 2001 Mk4 GTI
GIAC stage 1 - ECS stage 1 clutch & 14lbs Flywheel - 42Draft/Remus Exhaust - APR R1 dv - N75J - K&N
Single spring
So are you wanting a shorter spring so the collar sits higher?
The daily
White 2001 Mk4 GTI
Dubway
The daily
White 2001 Mk4 GTI
That looks very cool mate![]()
06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
Thanks to bflat, I will be getting some 10mm spacers tomorrow
Looking forward to seeing his car.
The daily
White 2001 Mk4 GTI
New ride height is looking hot mate! Any issues with driveshaft rubbing? Out of interest do you know how many mm you've dropped by?
Cheers man loving the Polo, just fitting the spacers now.
The daily
White 2001 Mk4 GTI
