Page 16 of 17 FirstFirst ... 614151617 LastLast
Results 151 to 160 of 162
Thread: White Mk4 GTI
  1. #151
    same as me, few blocks away. got a escort the rest of the way by my GFs dad (Vicroads hwy patrol) lights and all, smashed a few gears and got there in the end.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  2. #152
    Melbourne, VIC
    Oh man that sounds full on, i was on the beach blocking a t intersection busy as day too.
    Ive been reading up on it and it sounds really common hopefully I get another 140k out of the next one.
    Sent from my GT-N7105 using Tapatalk
    The daily
    White 2001 Mk4 GTI
    GIAC stage 1 - ECS stage 1 clutch & 14lbs Flywheel - 42Draft/Remus Exhaust - APR R1 dv - N75J - K&N
  3. #153
    Melbourne, VIC
    Fixed a boost leak on Sunday morning before my clutch pedal went.
    I made an adapter for my TIP out of a can and slowly boosted the system to 25psi, quickly found air coming out at the tip connection it was so bad cos the clamp had slipped off, I've tightened the hose clamp as much as for it to hold 25psi and that should stop any air getting in after the MAF which would of been giving me problem.
    Boosted so much better in the quick drive to the beach for a swim, I had just left when the clutch pedal failed so didn't get a chance to really check it out
    Getting a the car back tomorrow afternoon, so looking forward to it.
    The daily
    White 2001 Mk4 GTI
  4. #154
    Melbourne, VIC
    Played with the wastegate actuator again today got it set to stock 6psi physical and plugged back in and hit 18psi finally (after a drive to the city in 24c on road temps and stock SMIC).
    So with that running at 4psi and the leak on the TIP it was running soo sluggish.
    Recommend checking it just unplug the n75 and it should be 6psi on a boost guage for a stage 1 tune if its not tighten in small amounts to get it to 6psi clear the codes with a reset (I use vagcom) and enjoy the extra power and response.
    The daily
    White 2001 Mk4 GTI
  5. #155
    Melbourne, VIC
    Well I've not been on for awhile but still busy with things then had a smash in her .
    In the shop now getting fixed and getting something I've wanted done for a while, I'll post pics when I get her back
    Sent from my T0LTE using Tapatalk
    The daily
    White 2001 Mk4 GTI
  6. #156
    Bummer! Hope not too bad and you are ok!
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  7. #157
    Melbourne, VIC
    Cheers Dylan I was fine, just got her back today.
    While it was in I got them to colour code the valances they ended up spraying the whole rear bumber as well here is some quick picks after I picked her up.
    The daily
    White 2001 Mk4 GTI
  8. #158
    Nice! Think you need some side skirts now to match the front lip
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  9. #159
    Jun 2009
    Looks ace but you know it's begging for black badges and headlight surrounds now haha.
  10. #160
    Melbourne, VIC
    Haha yeah the old front black badge and grill are in the boot they did a new stock one for me
    Sent from my SM-N9005 using Tapatalk
    The daily
    White 2001 Mk4 GTI
