Page 11 of 17 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 162
Thread: White Mk4 GTI
  1. #101
    Melbourne, VIC
    Quote Originally Posted by Tim View Post
    its pretty easy. Off the top of my head.
    Just put the rear of the car on stands. Undo the top strut mounts and you should be able to remove the springs/adjusters.
    Toss the unrequired pieces/reassemble
    Thanks Tim is this something you could give me a hand with, i've been meaning to make the drive over to your place one Friday
    Sent from my GT-I9100
    The daily
    White 2001 Mk4 GTI
    GIAC stage 1 - ECS stage 1 clutch & 14lbs Flywheel - 42Draft/Remus Exhaust - APR R1 dv - N75J - K&N
  2. #102
    Point Cook, Vic
    If you pop over tonight there will most likely be several internet mechanics willing to lend their expert opinions
    FOLLOW US ON FACEBOOK
  3. #103
    Melbourne, VIC
    Nice, I'll see you guys tonight, I'll be coming from Altona so I'll be around a bit later.
    The daily
    White 2001 Mk4 GTI
  4. #104
    Mar 2011
    Wagga Wagga
    did you end up doing more lows ?????? you bringing the car to dub-stitute ill be making the trip in my mk 4
    2.0 mk4 golf (SOLD)
    mk1 76 4door ( long project)
  5. #105
    Melbourne, VIC
    Quote Originally Posted by samSC1192 View Post
    Yeah man yes to both will be good to catch up, I have only taken out the lower locking collars in the rear and evened out the front and hardened everything up still have some rubbing with big dips but its pretty good.
    The daily
    White 2001 Mk4 GTI
  6. #106
    Mar 2011
    Wagga Wagga
    Quote Originally Posted by theOctopus View Post
    sounds good if been meaning to take my locking collars out in the rear except i think it will look funny cause the tire will be completely tucked and will scrub non stop. i defs wanna lower my car a little for the weekend tho i need to get my act together and buy smaller rims .
    2.0 mk4 golf (SOLD)
  7. #107
    Melbourne, VIC
    well dramas again with the car,
    changed the dog bone mounts on the weekend.
    so so dirty
    When I took it for a drive it felt like my teeth were falling out, swapped out both the larger and smaller mounts with the stock ones still really bad, also the exhaust tips have moved under the valance, the old mounts must of sagged heaps.
    just spoke to Dean from Volkwerke and he noted that if I had a custom exhaust that with the new mount it maybe hitting the chassis somewhere and causing the vibration, so going to install the old mounts if the vibration is gone ill book it into the exhaust shop and fit the new mounts before I go in and have them readjust the pipes to stop it banging, I hope.
    any other ideas guys.
    The daily
    White 2001 Mk4 GTI
  8. #108
    Melbourne, VIC
    dramas all fixed my bad installed the wrong way, the down pipe was hitting the steering rack , feels real good now tho
    The daily
    White 2001 Mk4 GTI
  9. #109
    Mar 2011
    Wagga Wagga
    thats good that it was something simple and can just learn from it im gunna have fun in the next couple of weeks putting a new drive shaft in/ trying to drill the snapped off bolts out of the side of the gear box where the cv connects
    2.0 mk4 golf (SOLD)
  10. #110
    Melbourne, VIC
    Haven't updated the thread for a while but ive still been doing things only small tho.
    Did a full engine bay degrease and clean which looks so much better, did an oil and filter change with motul turbolight.
    New badges
    Got some vinyl to play with
    Oh and a wee bit lower
    Height from ground to top of arches:
    Front 24 1/2 inches
    Rear 24 3/4 inches
    The rears were a lot higher so the front had no change only the rear.
    The daily
    White 2001 Mk4 GTI
