Page 5 of 5 FirstFirst ... 345
Results 41 to 44 of 44
Thread: VW Jetta 2.0 16v TDI (BKD) - 301hp & 440Ft/Lbs GTB2260Vk, Tubular Manifold, Race PDs
  1. #41
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by ryanp View Post
    it still pulls very well from low RPMs. What you lose at the bottom end is nothing compared to what you gain at the top end
    At what rpm do you feel the turbocharger begin to spool?
    I'm wondering how much you loose from idle before the stock torque is equalled (and then bettered, of course).
    Like Greg, I'm also very interested in the Southbend clutch/flywheel kit. Which spec will you get (Stage 1/2/3, Daily/Endurance/Drag/Extreme)? I guess not Stage 1 since their torque limits are already exceeded by your engine
    Resident grumpy old fart
  2. #42
    Oct 2011
    South Yorkshire, UK
    We use Stage 2 Endurance in the Caddy but will be using a Stage 3 in the Jetta.
    The turbo spools super strong from 2000rpm onwards, Full boost (2.5bar) is around 2500, it has more torque than standard or remapped at ANY rpm.
  3. #43
    Oct 2010
    Melbourne, VIC
    Even directly off idle? It's from there to about 1500rpm that particularly interests me.
    And will you be using Endurance again at Stage 3 for the clutch/flywheel?
  4. #44
    Oct 2011
    South Yorkshire, UK
    who drives WOT below 1500rpm? no-one I know! haha if you want to drive like that get a 1756!! that spools quicker than stock!!
    Yeah Endurance if we go Stage 3.
