Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: VW Jetta 2.0 16v TDI (BKD) - 301hp & 440Ft/Lbs GTB2260Vk, Tubular Manifold, Race PDs
    Oct 2011
    South Yorkshire, UK
    Here are some pics of it when I got it:
    First up is the chassis -
    Audi 18" x 8.5" Fat Fives with 225/40/18 Uniroyal Rainsports
    KW V1 Inoxline
    We also fitted an Audi TT 2.0 TFSI Rear Axle and Alloy Hubs that gave us 26mm more width and TT Front Alloy Hubs and Cast Wishbones, which give an extra 30mm and more camber. I have loads of pics, but didn't upload them. Everything is much beefier and lighter.
    R32 345mm Front and 310mm Rear Discs. The front calipers have a TyrolSport Caliper Stiffening kit, which I would recommend it to anyone. Google it and see what I mean.
    Oct 2011
    South Yorkshire, UK
    We used Eos 3.2 FWD Splash Guards with fit perfectly with a slight modification
    And it looked like this:
    We then fitted a Darkside Developments EGR Delete and removed the EGR cooler completely:
    After we mapped it and took it to the dyno, here were the results:
    Some little interior mods -
    Scirocco Flat Bottom MFSW
    Passatt CC Switches
    Thats how it stayed for a few weeks, but we had plenty more in the pipeline.
    Oct 2011
    South Yorkshire, UK
    We then concentrated on the body mods, we did the following:
    Golf GTi Front bumper with Summer grills
    Jetta GLI Rear Valance
    Hella Projectors with Lamin-X Gun Smoke Tint and Osram Nightbreaker Bulbs
    Smoked Rear Lights
    Smoked Reflectors
    Smoked Indicator Lenses
    Smoked Numberplates
    Rolled and Flared arches
    Black VW Emblems
    Here is how it looked:
    Next was to fit the Darkside Developments 2.0 16v TDI Turbo kit with a GTB2260VK Turbo from a 3.0 v6 Audi:
    Along with an S3 Intercooler and hard pipe kit (I didn't get a pic of the cooler before we fitted it, but it is all alloy with welded end tanks and no clip connectors):
    Milltek 3" System (made for a US Jetta GLI):
    We also modified the MAF, as it was deleted from the map:
    Then we took it to the same dyno so see what we were making
    235.3BHP and 330Ft/Lbs. This is on a very conservative dyno (the operator calls it the 'heartbreaker') with ZERO smoke and a very road friendly tune. 3 days after fitting the turbo I drove 1500 miles to, from and around Cornwall and averaged 57mpg for the whole trip. It didn't skip a beat.
    We still have some adjustment in the stop screw to get the boost to come in a little earlier, but it still pulls very well from low RPMs. What you lose at the bottom end is nothing compared to what you gain at the top end, it pulls like crazy to the 5000rpm fuel cut we have in the tune and pulls 130mph in 5th easily. I have found the 140mph electronic limit though, which we are working on removing ASAP!
    Oct 2011
    South Yorkshire, UK
    Next on the agenda are a Sachs SRE Single Mass Flywheel and Sintered Paddle Clutch, Peloquin Limited Slip Differential, fitted to a low mileage PD170 Long Ratio Gearbox
    Someone on the Edition 38 forum posted up a pic of the Jetta at their show:
    We then fitted the Sachs SRE Single Mass Flywheel and Clutch and a PD170 Long Ratio Gearbox with a Peloquin LSD Installed. We also strengthened the shifter forks so we can do some fast changes. Once the clutch was run in, a set of Race PD Injectors was dropped in.
    Here are the results from this afternoon:
    We did 3 pulls and they were all pretty close together, the best run was 301hp and 440Ft/Lbs.
    And here is a graph comparing the stock power to now, we have made pretty good progress!
    Here is the spec we have now:
    2.0 16v BKD PD140 Engine
    Darkside GTB2260Vk Turbo Kit with Tubular Manifold and 3" Downpipe
    Darkside Race PD Injectors
    Darkside FMIC Kit with S3 Intercooler and Alloy Pipework
    Darkside EGR Delete Race Pipe (Retaining ASV)
    Milltek 3" Non-Resonated Exhaust System with Twin 76mm Jet Silencer
    Darkside Developments Re-Map with MAF and EGR Delete
    301BHP & 440Ft/Lbs – Dyno Proven
    PD170 BMN Long Ratio Gearbox
    Sachs SRE Single Mass Flywheel with Sintered Paddle Clutch
    Polyurethane Filled Dog Bone Bushes
    Darkside Developments Short Shift and PU Filled End Links
    R32 Front Brake Calipers
    R32 345mm x 32mm Brake Discs
    Genuine Audi S4 Front Pads
    R32 Rear Calipers
    R32 310mm x 20mm Rear Brake Disc
    Genuine VW Rear Pads
    Eos 3.2 FWD Rear Splash Guards
    Silver Zinc Plated Calipers
    KW V1 Inox Coilovers
    Audi TT Front and Rear Top Mounts
    Audi TT Alloy Front Wishbones with Solid Bushes and Adjustable Ball Joints
    Audi TT Alloy Front Hubs and Alloy Track Rods (26mm Wider Track)
    Subframe Spacer Kit
    Audi TT Driveshafts
    19mm Front ARB
    Audi TT Rear Axle with Alloy hubs (30mm Wider Track)
    Passat R36 21.7mmx3.6mm Rear Anti-Roll bar
    Audi A8 ‘Fat 5’ 18”x8.5” ET45 Wheels
    Uniroyal Rainsport 2 225/40/18 Tyres
    Genuine VAG Wheel Bolt Caps
    18" Spacesaver Spare
    Smoked Rear Lights
    Smoked Reflectors
    Black VW Emblems
    Leather Sports Seats
    Scirocco R / Golf IV Multifunction Steering Wheel
    Scirocco Headlight, Mirror and Window Switches
    I-Pod Adapter in Armrest
    Next step is a cam, headwork and bigger injectors. All of which are difficult to source, but I will find them!
    Any questions, please don't hesitate to ask!
    Thanks
    Ry
    Q
    Waaaah, very nice. Great work!
    Oct 2009
    Canberra ACT
    Very Nice! That thing sounds like a weapon
    06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
    holy jesus. 600nm at the front treads! That thing must be a handful!
    Nice work
    got a in car video of it yet?
    p.s some of your photos didn't work
    Oct 2011
    South Yorkshire, UK
    Thanks Guys, Videos will follow shortly!
    Which pictures dont work? they are all hosted on the same server so in theory it would be all or none!! haha
    my computer obviously had a hissy fit. All there now! Nice Dyno graphs!
    Jun 2008
    melbourne
    Loving the wheels on this!
    White Scirocco R
    White MK3 Golf 2dr
    White Caddy (Work Van)
