Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: UK car- GTI Engineering Golf Syncro
    Jun 2009
    Derby- UK
    copied from a previous thread
    b]History[/b]
    GTI Engineering was originally founded by Richard Lloyd in '78. He was racing a Mk1 GTi and went on to win classes in the British Saloon Championship in '77, '78' and '79. These wins also attributed to the launch of this car in the UK. They developed and produced a range of sports conversions. In '82 VAG appointed GTI Engineering Official Audi Volkswagen Conversion Specialists, which meant conversions could be undertaken without affecting the warranty. They became dealer #315.
    Standard GTI 8v RE2000 Conversion
    tuftrided EN 24 crankshaft with 94.5mm stroke
    machined cylinder block of 82mm bore
    lead-idium heavy duty cranshaft bearings
    lightened and balanced crankshaft
    alloy autothermic pistons
    gasflowed cylinder head with enlarged port diameters
    gasflowed inlet and exhaust manifolds
    42mm inlet valves (40mm on the carb head due to space limitations)
    35mm exhaust valve
    276 Schrick- (im still deciding between a 276 and 268 as mine had a standard cam fitted)
    uprated valve springs
    uprated oil pump
    windage tray and sometimes an Oettinger baffled sump
    modified distributor and injection system on the GTI
    Compression ratio 10:1
    Power 8v GTI
    152bhp @ 5500rpm
    158lbs/ft @ 5500rpm
    0-60 7secs
    0-100 20secs
    Max sped
    130mph
    Cars
    The first Syncro conversion was a LHD Syncro Gt 2 door 90bhp injection model, fitted with a Recaro interior and ABS. A more detailed review can be found in Volkswagen Audi Car magazine Aug '88 or Car magazine May '88. This was also the car featured in the later GTI Engineering brochure and was fitted with their Aero Tech body kit.
    I have contacted a former employee and they say that 4 conversions were carried out on Golf Syncros, but there is no further information of what spec they were. I only know of the above car an my RE2000 Syncro. Any more info is always appreciated and I would like to meet any others owners!
    My car
    It was converted by GTI Eng 10 days before the registration date. When I bought it, it had covered 100k and was almost standard apart from a set of multi-spoke alloys and 16v rear clusters. It was still running on the original re-jetted Pierburg 2E2 carb. It was in reasonable condition and was fitted with the Syncro CL Sports interior.
    It is keeping the original interior along with a few touches and a late GTI Eng steering wheel that came from a Rallye. I have also pinched the anti-roll bars, exhaust manifold and downpipe. The d/p with have to be modified to fit and Ill have a custom stainless exhaust system. I have fitted FK Konigsport suspension. Im awaiting a Powerflex bush kit, except for the trailing arm bushes. Im fitting a set of eccentric bushes instead. The front brakes have been uprated to 16v spec with a Goodridge brake lead set. The fuel system has also been upgraded with pump and filter/regulater. I am also waiting for a full Missinglinkz tramsmission set and MJ Interiors to do a couple of jobs. There is also a set of VDOs fitted. It was painted up at Volkskraft with a few subtle body mods. It will be a discreet Retro look and was to have the set of polished wheels that Im using on my daily driver at the mo. Look further on to see what it will be wearing now...
    Jun 2009
    Derby- UK
    theres been a bit of a change to the carb selection. If I fitted the single, it will involve a substantial [:0] modification to the bulkhead,
    so Im fitting a pair of 40 downdraft carbs instead. Should hear this start up very soon (at last)
    Jun 2009
    Derby- UK
    If i was doing this from the start, then i would have gone for a crossflow, but I dont want to distract from the original engine as a carbed GTI Eng is a bloody rare engine in itself. You can fits DCOEs with 12-20mm trumpets provided you make a sufficient headshield to combat the exhaust heat. im getting the manifold ceramic coated and the downpipe wrapped. if you were fitting DCOEs it would also be a good idea to make some kind of airbox or ducting device as well.
    Repaired bulkhead now looks like this
    Jun 2009
    Derby- UK
    heres up up to date pic. It aint staying this low but I couldnt resist a pic
    Ive had a lapse in momentum after spending a lot of $$ lately and not making my planned debut date, but im sure ill pull my finger out soon
    Jun 2009
    Derby- UK
    well, ive moved and got a garage now, so i will be finallly pulling my finger out. Ill post pics as the long awaited progress gets going again.
    Final-ish ride height
    GTI Engineering steering wheel
    Syncro Sports Interior
    This is the only golf or jetta this interior is found in. It also comes in ythe older b2 passat and some mk2 polo coupes
    just bought a new set of alloys! Golf Country Chromlux Calmasters!!!
    I am so happy! Just hope they are as good as the pics. Now selling my other 2 sets of ATS
    Jun 2009
    Derby- UK
    Added more pics to the net so here goes
    SYNCRO RESPRAY [url]
    Jun 2009
    Derby- UK
    Jun 2009
    Derby- UK
    Jun 2009
    Derby- UK
    Jun 2009
    Derby- UK
    and a little teaser of the carbs
    the car has been stored for over 2 1/2 years at a garage under a sheet. The pilfering pixies who robbed my exhaust knackered the paint on everything that was stored in there along with the car itself. Ive just dropped it back at the painters and Ill get it back next weekend.
    Heres another carb pic
