Hey all. I don't frequent VWWC as much as I do VWGolf but I do tend to come on here from time to time when I feel like getting away from the MK5/MK6 stuff and looking at all things VAG.
I did have a MKV Jetta which was on its way to becoming nicely modded until it got written off due to some idiot not looking while he was turning and not giving way to me, resulting in me T-boning the car and writing it off.
Link to Jetta build thread
Thought I'd make a thread on Golf R and share with you all
As at 01/07/2015 :
CAR : Golf R 5 door
YEAR : MY11 2010 (October Build Date)
COLOUR : Candy White
TRANSMISSION : DSG
FACTORY OPTIONS : Recaro Bucket Seats. RNS-510. MDI iPod. Reverse Camera. 19" Talladega Wheels (Black).
MODIFICATIONS
ENGINE
SpecTune Custom ECU Flash (Aggressive Tune)
Volant Cold Air Intake
Scorpion 3" Non-Res Turboback Exhaust (ceramic coated DP)
EVOMS Heatshield (ceramic coated)
Autotech HPFP
EuroJet FMIC
Turbosmart Plumb Back DV
NGK PFR7B Double Platinum Spark Plugs
OEM Audi R8 Red Coilpacks
OEM Audi RS4 Fuel Rail Valve
Neuspeed Charge Pipe
Neuspeed Hi-Flo Discharge Pipe
Forge Oil Catch Can
Forge Silicone Intake-to-DV Hose
ECS Billet Oil Filter Housing
ECS Magnetic Oil Sump Plug
SUSPENSION
KW V3 Coilovers
KW Camber Top Mount Plates
H&R Front Sway Bar (24mm : Hard Setting)
H&R Rear Sway Bar (26mm : Hard Setting)
VWRacing Low Engine Mount
VWRacing Side Engine Mount
VWRacing Transmission Mount
SuperPro Lower Control Arms
SuperPro Lower Ball Joints
SuperPro Anti-Lift Kit
UniBrace UB Chassis Brace
Tyrolsport Rigid Collars
BRAKES
Motul Dot 5.1 Brake Fluid
Goodridge Braided Brake Lines
Remsa F+R Brake Pads
Fremax 345x30 OEM Front Rotors
Fremax 310x22 OEM Rear Rotors
WHEELS
SSR Professor SP1 (19x9 ET37, 5x112 PCD)
SSR 79.5-to-57.1 Centrebore Hubrings
SSR Type 2 Centrecaps
Dunlop SportMaxx GT (235/35/19)
EXTERIOR
OptiCoat Paint Protection Sealant
Nanolex Wheel Protection Sealant
Nanolex Ultimate Glass Sealant
Lamin-X Clear Protective Film (Headlamps, DRL)
PySpeed White LED Licence Plate Lights With Resistors (No Error)
Amber LED Indicator Bulbs (No Error)
3D Design Bonnet Vents (Carbon Fibre)
OSIR Mirror Covers (Carbon Fibre)
OSIR GT6-S Telson Spoiler (Candy White)
Garage Vary Front Lip (Carbon Fibre)
ECS Hatch Pop Struts
ECS Blue Tint Aspherical Mirrors
OEM Audi R8 Oil Cap
OEM Audi R8 Coolant Cap
OEM Audi TT-S Engine Cover (Candy White with Gloss Black Accent)
OEM VW Battery Cover (Candy White with Gloss Black Accent)
OEM VW Fuse Box Cover (Candy White with Gloss Black Accents)
OEM VW Front Emblem (Gloss Black)
OEM VW Rear Emblem (Gloss Black)
UROTuning Rear Wiper Delete Plug (Gloss Black)
LAKIN Plate Holders (Slimline)
Black Window Tint
INTERIOR
White LED Interior Light Full Replacement Units
OEM VW Aluminium Glove Box Latch
OEM VW Golf MK7 Climatronic Unit
Custom Gloss Black Interior Trim
Custom Carbon Fibre Steering Wheel
S2TPP Paddle Shifter Extensions
JCaps Billet Seat Recliner Wheel Cover
Engraved "R" and "Eject" LED Dead Buttons
Engraved "Garage Button" LED Push Button Mod
OSIR O-Rest Dead Pedal
OSIR O-Pod Mono (Gloss Black)
OSIR Step-GT Door Sill Trim (Carbon Fibre)
DEFI Advance BF Control Unit
DEFI Advance BF 2.0 Bar Boost Gauge (White, 60mm)
LATEST PERFORMANCE FIGURES
Mainline Dyno (16/04/2011) : 160.1 awkw @ 106kph/290.6Nm Torque @ 54kph
-Stock, no mods
Mainline Dyno (29/04/2012) : 180.7 awkw @ 148kph/329.3Nm Torque @ 80kph
-GIAC Stage 1
-VWRacing Intake
Mainline Dyno (02/11/2013) : 218.4 awkw @ 148kph/675.6Nm Torque @ 70kph
-SpecTune Aggressive Tune
-Volant Intake
-Scorpion TBE
-EuroJet FMIC
-Autotech HPFP
-RS4 Fuel Rail Valve
-Neuspeed Charge & Discharge Pipe
-Turbosmart Kompact DV
PLANNED MODIFICATIONS
ENGINE / WHEELS / BRAKES
DSG Reflash Tune
Brembo GT 6 Piston BBK's with 355x32 2 piece slotted rotors
Brembo 310x22 Slotted Rear Rotors
INTERIOR
P3 Gauge (Blue/White) with Analogue Sender
OEM MK6 Golf R Colour MFD Cluster
Carbon Fibre Interior Trim
OEM 9W7 Bluetooth Unit
Alpine INE-Z928Ei Head Unit
Focal IFVW Tweeters with 2-way splits
Soumatrix Xtase Coaxial Speakers (F+R)
PICTURES
Picking up the car from dealers. (01/12/2010)
Factory Recaro Seats
LED White Lights (10/12/2010)
LED Rear Licence Plate Lights (10/12/2010)
No Tint VS Tint (14/12/2010)
S2TPP Paddles. Black VS Silver (19/12/2010)
Whiteline Anti-Lift Kit Installed (02/02/2011)
Unibrace UB Chassis Bracing (02/02/2011)
Hatch Pop Gas Struts Installed (17/03/2011)
Video of Hatch Pop
H&R Sway Bars & Blue Tint Aspherical Mirrors Installed (05/04/2011)
VW + Audi Dyno Day @ Mainline Dyno, Revesby (16/04/2011)
Stock Golf R.
Power : 160.1kw @ 106KPH
dTorque : 290.6N.M @ 54KPH
