Results 1 to 9 of 9
Thread: Stellio78 - Changes 2 My GTI
    Jun 2016
    Sydney, 2224
    Had the car for about 10 months now and I've made a few small changes so thought I'd start a thread to discuss possible future changes and through up a photo every now and then.
    Changes so far:
    Tinted windows
    VW wind deflectors up front
    VW boot liner
    Boot compartment LED
    VMR V710 18x8.5
    VWR panel air filter
    Clutch spring and bleed valve delay removal
    And a pic from this arvo after a bath
    Attached Thumbnails Attached Thumbnails Stellio78 - Changes 2 My GTI-img_0181-jpg
    Jun 2016
    Sydney, 2224
    I'm thinking I might like to lower my GTI a little.
    These seem to be what I'm after Emmanuele Design “eMMOTION” Lowering Spring Kit (MK7 / 8V) – AutoInstruct
    I've never lowered a car before so what needs to adjusted on the MK7 after the lower springs are installed?
    Nov 2009
    Quote Originally Posted by stellio78 View Post
    They're good springs; I have them on my S3.
    You need to do a full wheel alignment after lowering. That should be it.
    Jun 2016
    Sydney, 2224
    Thanks
    So you didn't need to make any headlight adjustments? Thought I read somewhere that people do.
    Nov 2009
    No, as long as you've got factory bi-xenons, which include self-levelling hardware (mandated by law). I'm not aware of anyone in Aus who's needed to have them adjusted after lowering (and these springs are only a modest drop anyway).
    Aug 2015
    Dumb question time: Lowering with springs doesn't affect the dynamic ride stuff does it? My understanding is that that is all related to the dampers.
    2017 MKVII Golf GTI | Pure White | DSG | DAP
    Instagram @purewhitegti
    Nov 2009
    You don't want to drop too far, as the dampers may be damaged. They're designed to operate at a certain ride height; by lowering, the dampers are no longer operating in their optimum range so ride quality and damper performance may be affected. However a modest drop like that provided by the ED springs is usually fine. Just bear in mind that any changes to springs is likely to void the warranty on your dampers (and potentially other suspension components).
    Aug 2015
    Sweet. Thanks heaps mate, some good food for thought. 👍🏻
    Jun 2016
    Sydney, 2224
    Thanks for the info Adam, the ED springs are on my wish list
