Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 100
Thread: Sam's Mk4 Golf 1.6
  1. #31
    Jul 2010
    Woodvale, WA
    Yeah man, still on the 215/35/18s. The photo I posted two days ago is wound right down and still up on the hoist. Just after I took it, we lowered the hoist and we realised that front struts were coming up and through the chassis a good 5-10cm.
    We fixed that by using the top hat things from the original suspension (between the struts and the body), and that worked well. By then we'd run out of time / daylight so the front coils are wound all the way up, which looks le crap. I'll wind them down on the weekend probably then get another wheel alignment. How much would changing the front height like that actually throw out the wheel alignment?
    Edit: Hmm, rear's wound all the way down and it's not sitting as low as I want it to be.
    (remember, the fronts aren't wound down yet)
    Considering taking out the perches? That'll get me another 1 or 2cm, right?
  2. #32
    wooooo that doesnt look right up front. you put teh bearings and bushes in yeah?
    yeah rear should go a little lower. iv never taken my adjusters or perches out and it almost tucks a 215/40/18 on the back
  3. #33
    Melbourne, VIC
    Quote Originally Posted by saMfish View Post
    dude don't take out the perches, just take out the lower locking collars and wind down the top collar all the way to the perche, it should give you another 9 to 12mm drop and keep everything secured. at least try it first and see what you think.
    The daily
    White 2001 Mk4 GTI
    GIAC stage 1 - ECS stage 1 clutch & 14lbs Flywheel - 42Draft/Remus Exhaust - APR R1 dv - N75J - K&N
  4. #34
    have you got the rears how they are in this picture with the adjuster all the way to the bottom?
  5. #35
    Melbourne, VIC
    oh sorry guys missed that, single adjuster, if you were to remove the adjusters and leave the perche you would need to find a ring to keep the spring centered on the perche, I ran no adjusters for dub-stitute and there was lots of movement but it was only for one day, and when you jack the car only a small amount at the rear the spring falls out of the top mount only the perche kept the spring in place, so I would hate to see how bad it is with no perches the risk of the spring falling out would scare the crap out of me
    The daily
    White 2001 Mk4 GTI
  6. #36
    Jul 2010
    Woodvale, WA
    Yeah man, the adjusters are all the way at the bottom. Wouldn't the weight of the car while driving be enough to hold the springs in place if I took out the perches? Hoping to wind the fronts down tomorrow, will post photo(s) when I have!
  7. #37
    Feb 2010
    Launceston, tas
    Yeah with the perches out even when jacked up the springs will still stay in there, so there is pretty much no chance they will pop out. I ran no perches for ages(till i got defected). I have the exact same coilovers and they ran fine.
    Now the fun begins with problematic swaybar rubbing, Shaft rubbing on frame, axle bind, your tyre rubbing on pretty much everything under there ripping apart your fender liners....oh And the good ole "can't go through the maccas drive through cause i can't get over the speed bumps
    haha but we totally love it! Looks the goods anyways mate, love that colour.
  8. #38
    Jul 2010
    Woodvale, WA
    Wound down the fronts today, hella yeah! Wheel alignment / removal of rear perches booked for Thursday.
    Just an iPhone photo for now; I took some better photos that I'll put up when I get my mac running again (magsafe/charger port died.. 2nd one in 2 weeks >.>)
    ---------- Post added 06-02-2012 at 10:35 AM ---------- Previous post was 05-02-2012 at 05:48 PM ----------
    Haven't had time to go do a proper shoot at a location, but here
    I've also come to the conclusion that I need to buy some wheel spacers... 20mm? 10mm? What do you think, peoples?
  9. #39
    Melbourne, VIC
    looks awesome, and nice to know the rear springs won't fall out tho I don't think I can get enough drop in the front on mine to match the rear drop if I took my perches out .
    The daily
    White 2001 Mk4 GTI
  10. #40
    Jul 2010
    Woodvale, WA
    Thanks man yeah haha, that's the one downside I found with the FK coilovers; they don't go as low.
    Pretty sure it's sagged a bit already, this makes me a happy camper
