Yes it is recommended to do an oil change after running this product through the engine. I do an oil change either on the same day or the day after using the intake decarb product.
Yes I will put some info together for you over the next few days on the catch can. When I did the intake clean (shortly after buying the car and prior to fitting the catch can) I cleaned everything I could access without actually removing the inlet manifold. I do plan on removing the manifold one day and cleaning it all out - but havent gotten to it yet. Before doing the most recent decarb which was about 2 months ago (before the cars annual service) I used a torch and inspection mirror to look at the manifold flap and other areas I had previously cleaned. They were still quite clean with just a thin layer of muck on them which came off easily with the decarb spray.
Regarding the length of rubber hose, I would have preferred to have mounted the catch can closer to the engine, but I simply couldn't find an area with enough room to fit the catch can while also being accessible (needs to be drained every 5000km or so which only takes a minute or two do to, as well as checking the filter ever now and then).
Have a chat to Darkside about what you would like to do. Even if you buy the parts required from them and have it tuned elsewhere (they might even have partnerships with other tuners in the UK?). Darkside are currently playing around with an Audi A6 on their Youtube channel which has the same V6 bitdi engine as our SQ5's.
