Playing with an Audi SQ5 TDI
Ok so is been 6 months or so since I updated this thread. Not too much has been going on with either car as ive been busy with other stuff like moving house etc.
But I did replace the brake disks on the SQ5 a few months ago. They weren't too bad, but the 40,000km or so they had done with the original brake pads before I replaced them with less aggressive pads had worn a good amount of the usable disk surface away. I got the Bremtec cross drilled disks for the front and Bosch disks for the rear. Shame that Bremtec dont make a matching rear disk but oh well.
I noticed that the coolant in the overflow bottle became discoloured all of a sudden. The coolant became very dirty/rusty looking and it stained the coolant tank. After doing some research, this is relatively common as the coolant overflow tank has a silica bag inside which is designed to make the coolant last longer, but if this silica bag fails then it makes the coolant go all rusty and dirty looking. Great!! I ordered a new genuine coolant overflow tank, some G13 concentrate coolant + demineralised water and a Draper coolant vacuum filler Draper Tools Expert Universal Cooling System Vacuum Purge and Refill Kit For Sale Online | Mektronics | Draper Tools. I drained the coolant, flushed it with various Nulon and Penrite coolant flushes, flushed it about a dozen times with just water, and then finally once I was satisfied the system was pretty damn clean - did the final fill with fresh G13 + demineralised water mixed 50:50. Thankfully, its been several months since this ordeal and the coolant is still a nice pink colour and very clean.
Took a gamble on some alloy sway bar end links simply to replace the factory plastic ones and they were a perfect match. Run Auto Parts sell these.
Also decided (just for an experiment) to replace the tiny 6.5" subwoofer which is part of the optional Bang & Olufsen stereo upgrade on these cars. The original "sub" was of pretty poor quality which was not a huge surprise, so I grabbed a $120 Hertz sub (theres not very many options in 6.5") and fitted that. Not much difference and definitely not worth the $120 or so it cost but it's done.
https://www.vwwatercooled.com.au/for...d9550fc4-1.jpg
https://www.vwwatercooled.com.au/for...8ec64302-1.jpg
https://www.vwwatercooled.com.au/for...f4675565-1.jpg
https://www.vwwatercooled.com.au/for...bd668f3e-1.jpg
https://www.vwwatercooled.com.au/for...07c44382-1.jpg
https://www.vwwatercooled.com.au/for...67961ba0-1.jpg
https://www.vwwatercooled.com.au/for...5e51b86a-1.jpg
https://www.vwwatercooled.com.au/for...c1986021-1.jpg
With a bit of time off over Christmas I decided to remove the 2x DPF's, inspect them and give them a clean seeing its been a few years since I last looked at it. I was looking at some of the DPF cleaning sprays (which actually do not require the DPF to be removed, but seeing its very quick and easy to do, plus I wanted to see the before vs after I removed the DPF) and decided to try the Penrite P26 DPF cleaner out simply because they were in stock (and on sale) and my local SuperCheap Auto and saved me having to buy another brand and have it shipped from Sydney or Melbourne.
Penrite DPF Cleaner P26 400mL | Supercheap Auto
Before I removed and cleaned the DPF, I took the car for a drive and performed a regen. So soot level was low at 6.73 grams which is about normal after doing a regen (anywhere between about 6-8 grams).
The DPF catalyst looked visually clean after the regen so I was curious to see what (if anything) the cleaner was going to achieve. This process was more of a curiosity or experiment than anything else as I do not have any DPF issues and the car does regens every 500km or so. The spray comes out of the can in a thick foam, and then slowly shrinks/liquifies/evaporates. I used both cans but in hindsight, I think 1x can would have been enough. After leaving the product to soak into the catalyst for about 20-30 mins, I then flushed it out with the garden hose. I tried to capture the dirt that was coming out after the clean which I was able to capture in a short video.
DPF was left to drip dry for a few hours and then re-fitted to the car. No issues or error codes. Car has been driven about 1000km since.
https://www.vwwatercooled.com.au/for...7db2053b-1.jpg
https://www.vwwatercooled.com.au/for...a0413cda-1.jpg
https://www.vwwatercooled.com.au/for...ecf4e5b5-1.jpg
https://www.vwwatercooled.com.au/for...c6d92684-1.jpg
https://www.vwwatercooled.com.au/for...3cc87bc5-1.jpg
https://youtu.be/ZTBLiGzQWTA
Well its been 8 months since the last update on the SQ5 - not too much has happened as we bought a new house late last year and a lot of the money and time has been spent on the new house.
- Wagner intercooler and RS front grill - ready to be installed at the same time while front bumper is off
- 4x new Hankook Ventus S1 Evo 3 SUV tyres (265/40/21) and wheel alignment in June
- RSNav Version 4 screen upgrade (10.25") with Carplay - ready to be installed this weekend. Currently have another Carplay screen fitted which is fine, but the RSNav is supposed to be better - we will see.
- Car is due for its 90,000km service in September so ill probably remove and clean the intake once again before it goes for the service.
Unfortunately the custom Garrett intercooler that my brother was making for me has been put on hold indefinitely, as he passed away unexpectedly late last year. Hence why I have decided to buy the Wagner.
https://www.vwwatercooled.com.au/for...4f8ea4b3-1.jpg
https://www.vwwatercooled.com.au/for...29e0ba18-1.jpg
https://www.vwwatercooled.com.au/for...b696a640-1.jpg
https://www.vwwatercooled.com.au/for...a53b86ff-1.jpg
https://www.vwwatercooled.com.au/for...a7b77327-1.jpg
