Page 13 of 18 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 178
Thread: My other German fling: Mk6 GTI
  1. #121
    Aug 2011
    Lake Macquarie
    car yards do it all the time.
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
  2. #122
    It's been a while since i updated this thread - ive got a few goodies on the way which should turn up next week:
    - CTS catback exhaust
    - Koni yellow Sport shocks all round (adjustable dampening)
    - New strut tops, bearings and all bolts/hardware
    - BFI 70 duro dogbone insert (to replace the Spulen 80 duro one which gives too much vibration)
    - SPM 22mm rear swaybar
    - Gloss black OEM mirror caps
    - Twin reverse light conversion (same as i did on my R)
    - Vacar replica Xenon headlights which have been on order forever
    - R8 red ignition coil packs
    Looks like its time to get my DIY on again.
  3. #123
    Erskineville, NSW
    What setting are you running the konis on Lucas?
    I have Eibach Diesel Estate springs on my petrol hatch. The Koni / Eibach combination is brilliant on the rear with half a turn off soft but up front it always feels like it's pogo-sticking when I hit a bump eg: undersprung & underdamped. I've tried half off soft through to 1.25 off soft.
  4. #124
    Still looking into the settings Brad - the suspension shop suggested to set them mid way and see how it feels and adjust from there if neccessary....not sure if thats a good suggestion or if they have no idea??
    Been looking at a few threads from the USA with info on peoples settings...although everyone is different in their wants and needs and it also varies depending on what springs you are running of course (spring rate, fixed rate or variable rate springs) and also how low the car is.
    I have the SPM springs which lowered the car approx 30mm at the front and about 25mm at the rear, but these springs have a pretty high spring rate.
    The rear shocks are a bugger to adjust as you likely know as they need to be removed, but the fronts should be ok via the strut tops.
    Ive used these Koni yellow sport struts on my old 200sx about 8yrs ago and found them quite good, so hopefully they will offer a similar feeling on the GTI.
  5. #125
    Erskineville, NSW
    No, I wouldn't start at halfway ( esp on the rears) whenever I've done koni I always start at half off soft. Friends tell me you should start at full soft but I heard that was bad.
    One thing that might be worth looking at is the length of the front bumpstops. It's sometimes worthwhile trimming 20-30mm off them.
  6. #126
    Ok ta - will keep that info in mind re the dampening. Just literally 5 mins ago ordered new (shorter) bump stops from ECS Tuning along with a few other bits and pieces.
  7. #127
    Oct 2010
    Melbourne, VIC
    If the diesel engine is quite a lot heavier than your petrol, then I'd expect it to be overdamped (jarring over bumps) rather than the pogoing effect you describe (see Damped Harmonic Oscillator) unless you have the damping set way less than optimal. Being rebound adjust only, if the damping was optimised for the spring rate being too high for your engine and you have the damping adjusted too low, then it have an odd jarring response from the bump and then a wobbly overshoot on rebound.
    Have you tried firming it to maximum just for a short drive to see if the behaviour is better?
    Resident grumpy old fart
  8. #128
    Up to my old tricks again....playing with intakes to make a custom hybrid version.
    The Unitronic intake is great but i was never 100% happy with the exposed air filter, even though it had a heat shroud fitted.
    So now its got a carbon fibre enclosed shroud to keep the heat away and the boys in blue happy. A bit of bling too
  9. #129
    Erskineville, NSW
    Quote Originally Posted by kaanage View Post
    Heavier springs need heavier damping - no? The Koni sports are the same partno no matter what engine combo you have but I'm happy to crank them up even more - I'll give it a shot.
  10. #130
    May 2012
    melbourne, victoria
    CTS
    hey lucas, glad to see that you've got more toys. i'd be interested in hearing what you think of the CTS catback (fitment, how they sound/drone), don't think i've seen a lot of Aust. examples of these installed?
    i ended up replacing my spm springs for a set of STS coilovers as i couldn't un-see the slightly higher rear height.
