Page 12 of 18 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 178
Thread: My other German fling: Mk6 GTI
  1. #111
    Sep 2014
    Newcastle, NSW
    I remember when this car was traded in 😄
    Nice work Lucas_R
  2. #112
    Quote Originally Posted by ETH94N View Post
    I remember when this car was traded in My other German fling: Mk6 GTI
    Nice work Lucas_R
    Haha hey Ethan - when i saw your username + location + the car i must admit i wondered if it might have been you? How are you? Looks like you sold that Commodore and grabbed a vRS?
  3. #113
    Mar 2014
    Melbourne, Victoria
    Great thread Lucas. Where did you source the R8 oil cap from? I'm interested in this for my MK3 Octavia RS (I believe it will fit?). Do you need to modify the R8 oil cap in any way to fit or is it a straight swap?
    Also, admire how you look after your ride. Any tips on keeping the engine bay clean, what cleaners to use? Thanks.
    Couple of little updates for the GTI this week:
    LED reverse light from Bold Sport (much brighter than the stock bulb, ill be buying 2x more of these for my R).
    R8 oil cap.
    Mk7 Climatronic unit.
    Walking Contradiction...
    MY15 Skoda Octavia vRS 162 Race Blue Combi
  4. #114
    Quote Originally Posted by vEnOm_oz View Post
    Great thread Lucas. Where did you source the R8 oil cap from? I'm interested in this for my MK3 Octavia RS (I believe it will fit?). Do you need to modify the R8 oil cap in anyway to fit or is it a straight swap?
    Hey Venom - you can get the R8 cap from here: Bold-Sport.com :: Audi R8 Oil Cap
    You might be the first person to try this oil cap on a MkIII Octy, but im pretty certain it will/should fit unless they have changed the oil spout on the engine. If by chance it does not fit, im sure you wont have much trouble selling it.
    The R8 oil cap splits into 2 pieces (top and bottom) and in order to get the cap to sit horizontally in line with the engine you need to adjust the top and bottom of the oil cap and then click it back together. Takes 2 mins to do and does not require any tools. Some info/pics here: Modifying an Audi R8 oil cap | Audi-Sport.net
    The engine bay is actually quite easy to keep clean. Every few times that i wash the car ill pop the bonnet and give the engine bay a very quick spray. I just use my snow foam lance with the car cleaner shampoo in it to quickly spray the engine bay area which loosens any dust/dirt/grease etc, let it sit for a minute or so and then spray off with fresh water. Then chamois all the water off. The key is doing it on a regular basis otherwise it becomes a bigger job and you need to use more cleaner and more water. If you do it often then you only need to use a small amount of cleaner and water. If you do not have a snow foam lance you can put some carwash and water into a spray bottle, and then use the spray bottle to spray the engine bay.
  5. #115
    Mar 2014
    Melbourne, Victoria
    Thanks heaps mate.
  6. #116
    Sep 2014
    Newcastle, NSW
    Yeah it's great
    2010 Octavia rs travel 50,000
    •Leather
    •Nav
    •xenons
    •front n rear sensors
    It's great, I love this car. Just need to improve it.
    So I'm be very interested to hear what you might think of upgrading..
  7. #117
    Quote Originally Posted by GoddyB View Post
    Hi Lucas, interested to hear if you experience an ill fitting PCV hose to the Podi supplied boost tap, as I had to Dremel the barbed end of the boost tap so the PCV hose would click on as it should. I also turfed the supplied silicon vacuum hose for a 3mm wall thickness type Cheers
    You are right, the supplied boost tap (which looks like a 42DD unit) does not allow the PCV hose to click onto it. Looks like ill have to modify it like you did. Im also using a better quality silicone hose.
  8. #118
    Whyalla SA
    Hmm, interesting, I have also experienced the little inline vacuum filters filling up with oil very quickly & since I have discovered I have a faulty PCV, I am replacing the OEM breather box with an 034 motorsports billet unit & 034 manifold plug/ boost tap & 42dd Ultimate Catch Can, so should hopefully kill a few birds
  9. #119
    Sep 2014
    VIC
    Love your attention to detail mate, but I have a question..
    ..did you really remove the seats and pressure wash them!? Wouldn't the foam retain a lot of the moisture and then mold?
  10. #120
    Quote Originally Posted by tranqme View Post
    Hey mate - yes i removed the seats as part of my cleaning regime. I didnt "saturate" the seats with the pressure cleaner, was more of a quick once over to get some moisture into the fabric and initial part of the foam to make cleaning easier.
    If you leave the seats out in the sun to dry really well they are fine.
