Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: More non-VAG content - Ford Fiesta ST build
  1. #21
    Next on the list
    - DIY Refurb the wheels using colour matched grey paint and 2pak clear coat
    - New tyres with slightly taller sidewall (either 215/40/17 or 205/45/17)
    - New steering wheel
    - Upgraded intercooler (stock front mount suffers badly with heat soak, and if intake temps pass 50 degrees Celsius, the ECU noticeably reduces power)
    - Powerflex engine mount insert Engine Mount Insert - Fiesta ST
    A box may have been delivered yesterday with one of the above mentioned items inside.
  2. #22
    Jul 2024
    Shaping up to be a sweet car
  3. #23
    New intercooler arrived and was fitted a few weeks ago. Headlights out, undertrays off, bumper off and some of the original plastic air diverters behind the bumper need to be either trimmed or removed to make room for the much larger intercooler.
    The original intercooler is not only quite small, but made to a very low price point and the quality is not very good. The new intercooler, although a china-special Wagner knock off, is certainly a vast improvement over the stock unit. Fitment was perfect, with everything fitting and lining up perfectly - with the only thing needed (which I knew about prior to purchase) was a 10cm long piece of steel flat bar to secure the top of the intercooler to the bonnet latch bracket. There was no trimming or modifying of the bumper required which I was happy about.
    The original intercooler is a known bottleneck on these cars, and not able to handle several full throttle runs without significant heak soak resulting in engine power being pulled back.
  4. #24
    Jul 2020
    Maroochydore Queensland
    Lucas, I have neither the skills or the enthusiasm to do what you do with your vehicles; it takes a special person to be able to fit this into your life, and at the same time give constructive detailed advice to many people on the forum. I am a keen observer of your posts and find them very interesting .Thanks for the continuing information and the interesting and methodical way that you write, and obviously go about your tasks. Cheers-John.
  5. #25
    Jul 2024
    Noice. Pity about that horizontal bar, if you could get rid of that you'd have even better results.
    One advantage with a car that's been around a few years is the availability of performance parts.
    2024 CUPRA Leon V Tribe Edition
  6. #26
    If anyone on here happens to be interested in this fun little go kart which is in absolutely fantastic condition and needs nothing spent on it, then i will soon be trying to find a new home for it.
