Were you in Adelaide recently? Swear that I've seen your car before!
Hi my names Carlos, thought I'd finally post up a thread about my car and what I've done to it over the few years I've owned it.
Mods so far...
Engine
Link g4+ extreme engine management
Garrett GT2871R .64ar (56 trim)
Bar-Tek T25 top mount cast exhaust manifold
IE forged connecting rods
Phenolic intake spacer
ARP head studs
ARP main studs
ARP crank pulley bolt
ARP cam pulley bolt
Custom 3" TIP
3" custom turbo back exhaust
Audi r8 coil packs
Siemens 630cc fuel injectors @ 3bar
USRT billet injector cups
Genesis high flow intank fuel pump
044 Bosch fuel pump mounted in an 034 motorsports 1L surge tank
USRT fuel pump wiring harness
k&n pod
CTS fmic
Forge throttle body hose
3" maf
Forge 008 dv
42 draft designs vta catch can
Driveline
Dieselgeek sigma 5 short shift kit
ECS stage 1 clutch and 21lb SMF
ECS Dogbone mount
VF engineering motor and transmission mounts
02J rebuilt and strengthened by Neat gearboxes
Wavetrak TBD
Raxles v2.1b axles
Suspension-brakes-wheels
KW V1 coilovers
R32 brake conversion. 334x32mm front. 256x19mm rear.
R32 Lower control arms- front poly bushed
R32 Spindles
R32 ball joints
R32 steering rack - poly bushed
R32 front sway bar
Mele HD sway bar endlinks
Poly strut top mounts
Whiteline 24mm adjustable rear sway bar
034 motorsports aluminium subframe bushings
Koya Drift teks 18x8.5 et30
Pirelli P1s 225-40-18
Exterior
DEPO Blacked out Headlights
Blacked out badges
Clear/smoked side indiators
+25kw worth of stickers
25th anniversary front lip
R32 replica side skirts
Seat Cupra R lip
ECS stubby antenna
Interior
Dual column pod with NewSouth boost and oil pressure gauges
Vent mounted Innovate wideband A/F guage
Headliner DIY re-trim
Future plans?
Better clutch, lighter flywheel, fix stuff that breaks
Some pics...
My first VWWC cruise, stock besides APR stage 1
Current engine bay
Recent pics
2010 VW Golf MK6 GTI - 3 door | Carbon Steel Grey | DSG | 19" VMR V705 | Carbonio CAI | APR RSC Turboback Exhaust + Stage 2 Tune
looks good man!
would love to see that cooler black or something to dull it down and highlight the wheels
Nah, had a visible FMIC and wasn't from SA! I've seen that GTI R32 replica as well.
Either way, looks very nice. Those Mk4 GTI's were so boring looking from factory!
Looking good, I remember test driving this ages ago at the dyno meet.
What sort of power does it put down now?
How do you find the clutch on take off?
Does it shudder or is it smooth?
Car looks good mate, personally I would've powder coated the intercooler black (but I'm old lol).
MK4 GTI: Custom Code Stage 2, K03S, 42DD exhaust, Bilsteins, whiteline F&R, 312mm brakes
MK6 GTI: MY13, DSG , very stock
Ducati 749
