Back all the mounts off but leave the bolts in and try to shake the engine.
What I did in the vr when it wasn't sitting 100%
Not much to update... Taken it down the coast a few times, and did a run up my nebo last weekend, had run faultlesslyalso got a gfb diverter valve as my eBay special was leaking above 15psi
also re-arranged the pipes a bit to hide the dv under the charge piping more a beater look. Pics for clicks...
Tight fit but nothing rubs
Wheel and tyre specs?
Sooo been a while between updates. Not much has been going on, she had been running sweet. Getting a bit sick of looking at my bumper not fitting right so I have decided to ditch the pwr core and buy the cts fmic kit, the core is about 20mm thinner so should fit a lot better and the pipes do look pretty.
Also had some spare time yesterday so I decided remove the afe intake and fit something a bit smaller. Found a pod sheild at autobahn that fit perfectly over my 3" k&n, just had to make space for the icm
Went to bunnings to get a bracket haha
And installed
How much was the fmic?
