Page 50 of 53 FirstFirst ... 404849505152 ... LastLast
Results 491 to 500 of 529
Thread: Lito's MK4 GTI
  1. #491
    Sep 2009
    brisbane
    Quote Originally Posted by Sirocco20348 View Post
    What are the rough costs involved. Harness, coil packs, throttle body, DBW accelerator pedal.. What else?
    Gavin pretty much hit the nail on the head with his reply. If you get everything from a wrecked car you could do it real cheap and probably make most of your money back selling the rest of the car. I would stear clear of a polo loomas the wiring lengths and mounting points may be different. My tt harness literally clipped into all the mounting points and grounds. I had to get most of the sensors separately az the guy already sold the engine but i still put it together for under a grand not including the tune.
    This is a complete list of all sensors that i replaced or added...
    Maf
    Map
    Coil packs
    Both o2 sensors
    Throttle body
    Accel pedal (get harness too!)
    Knock sensor x2
    Get a seperate wideband gauge as well, the innovate ones are like $300 and super easy to install.
    Youll also have to resistor the n112 and n249 or add these systems in but dont do that.
    The only thing i could think of that would make it tricky is if you have a t10a connector nearthe battery instead of a t14a connector. Apparently only really early mk4s came with a t10a connector but mine is nov 99 build and it has the t14a plug. Even if you do have the t10a plug its just a couple of wires that need repining.
  2. #492
    Sep 2009
    brisbane
    Also get these to mount your coil packs securely to the valve cover
    Part number 077905390 like $20 from ebay
  3. #493
    Jan 2011
    Gold Coast, QLD
    And then how did you tune your car?
  4. #494
    Sep 2009
    brisbane
    Well thats the fun bit!! The obd port works as normal so it's just like tuning any car with the me7 ecu (s3, tt, polo gti etc) im running the stock maf and injectors and just staying out of boost until i get the tune done through gavin. This is where having an afr gauge comes in handy
  5. #495
    Sep 2009
    brisbane
  6. #496
    Sucked in
    Just found a 7.5 TT loom and ECU.......
    What software are you running?
  7. #497
    Sep 2009
    brisbane
    Quote Originally Posted by simmo675 View Post
    Sucked in
    Haha nice work! Putting around on the stock tune at the moment until Gavin sorts my tune out.
  8. #498
    Quote Originally Posted by Lito View Post
    Did you have to re-code your key to the new ECU? The loom and ECU I sourced has the steering column and key with it, which got me thinking......
  9. #499
    Jan 2011
    Gold Coast, QLD
    Usually the foreign ecu needs to be coded to your car. And depending on what version of security you might need additional information. Let me know otherwise as I'm curious aswell.
    Ross-Tech: VAG-COM: Immobilizer 2 ECU Swapping
    Do you guys have a picture of the loom? Or where it might be in the engine bay? I can't really visualise where it goes.
  10. #500
    Sep 2009
    brisbane
    Well im running an immo defeat atm so i can worry about it later. Also means i can run my new cluster without the immoboliser shutting the car down
    http://www.clubgti.com/showthread.ph...ss-install-FAQ
    Thats a great thread and the first post gies throughthe harness and explains what everything does. Study that and the swap is a piece of cake
