Page 47 of 53 FirstFirst ... 374546474849 ... LastLast
Results 461 to 470 of 529
Thread: Lito's MK4 GTI
  1. #461
    Munno Para West Adelaide
    Thats unlucky lito! Hope you can get that sorted. Where did you get the seal for the inlet manifold and rocker cover?
  2. #462
    Sep 2009
    brisbane
    Quote Originally Posted by dubster99 View Post
    Yeah, I thought I'd give these a go as they were only $200 and people say they are rated to around 380nm. Looks like I must be making a bit more than that haha. I got the gaskets from Integrated Engineering, you can get them most places but I was buying their new crank pulley so I figured I may as well pick them up as well. Just be sure you buy large port intake manifold gaskets.
  3. #463
    Do you need two gaskets for the manifold?
  4. #464
    Sep 2009
    brisbane
    not normally but im running a phenolic intake spacer
  5. #465
    Sep 2009
    brisbane
    So looks like I've got some work ahead of me over the long weekend. I scored a manifold of Jmac that was already painted black so that has saved me a lot of effort, whoever painted it did a nice job too
    And just picked up my billet injector cups from usrt after over 4 weeks!!
    Apparently there was a hold upwiththe install tool so I said don't worry about it and they sent me a set of sweet wire brushes instead, made in the USA and erythang haha.
    So the to do list for the weekend is;
    Replace valve cover gasket
    Swap intake manifolds
    Replace throttle body and IM gaskets
    Install billet injector cups
    Install OEM (not ****ty ebay brand that's already acting up) coolant temp sensor
    Install VF engineering motor mounts (should be here tomorrow)
    Then drive it!!
    Then it's time to start thinking seriously about a clutch. Pretty set on the fx400, anyone know if I can keep my 228mm single mass flywheel with this clutch?
  6. #466
    I got my stage 3 clutch off four seasons and just got the plate, cover and bearing. That's running with the ECS fw.
  7. #467
    Let me know about the vf mounts lito as im keen for a set later on
  8. #468
    Sep 2009
    brisbane
    Sounds good to me! How much for the stage 3?
    Will do, everyone on the web seems to reckon they vibrate like mad... Oh well, cos race kar I guess
  9. #469
    Quote Originally Posted by Lito View Post
    clutch Clutch Kits, Flywheels, APR VW Performance & Audi Oem Parts Source FourSeasonTuning.com.
    6 puck affair, pictures in my cheapy thread.
  10. #470
    Sep 2009
    brisbane
    So I installed the VF mounts yesterday, all went smoothly except my engine was a bit off centre
    Managed to wrestle it mostly back into place. This is where it ended up
    Might get Jmac to see if he can get it sitting any better when it goes in for a clutch.
    Then today I installed the black intake manifold and changed valve cover gaskets.
