I love it! My house mates, neighbours and anyone in the back seat not so much. I would recommend resonated though, mine is non-res and gets a lil' droney on the highway.
Printable View
Haha I can imagine, I was just wondering because I've seen a lit of people running 3" into 2.5" for some reason.
I'm thinking same sort of setup for mine, 3" DP of some sort with high flow cat and custom 3" catback....may even go varex muffler just to have the option of silence (not that I'll want it very often anyway)
John at 42DD told/confirmed this with us, which I basically understand is:
3" DP is best for performance.
But with the Cat Backs, it's more of a choice:
3" will give you a bit better top end power, kW on the dyno, but rob a little low end power, and it'll be noticeably a bit louder.
The 2.5" will give a bit better low end power, losing a little top end, and be noticeably a bit quieter.
I'll try to find the actual quote from him, but I think that sums it up.
You really should've jumped in with us on that 42DD buy, we ended up getting 35% off!! The offer was meant to end on Tues USA time, but if you emailed them now you could maybe still jump in! ... You could maybe also jump in on shipping with one of the guys on here that's getting their exhaust sent to near you anyway... My full turbo back 3"-2.5" 42DD exhaust is only costing me about $1050 AUD, to my door! And that's including about $400 AUD shipping!!
Maybe just grab a 42DD 3"DP right now, and then get a varex muffler from elsewhere? I love the idea of those things! And that is probably why nearly all of us in the group buy got the 2.5" cat back, just that bit less unwanted attention from the boys in blue and judgemental frowners. >-( ..aka: the haters!
Spotted your car today man in the Myer Centre carpark, looks sooooo nice in person. I did the stalk drive by on my way out after work at around 2:45pm today. What specs are your wheels? Im too lazy to search through the 35 pages on here haha :)
edit: just seen 18x8.5 +30 all round = JIZZ
I've got a 3" catless downpipe to a 2.5" billyboat exhaust. I swear by it. Not too loud either. Although sometimes I wish it was a bit louder when doing some spirited driving haha. It's just a no name downpipe front eBay too. No problems with it whatsoever. Cheap as
So not many updates as of late. It hasn't broke in a while so I'm stoked with that!! Now that I have no boost leaks it's holding 20psi till redline but now I am running out of fuel pump. I've ordered an 044 and surge tank that I'm gonna mount in the stock intercooler location that should be good for 600hp :) hopefully that'll stop it leaning out up to and then we can turn the boost up a bit :driver: oh and the wavetrak is still sitting in its box :facepalm:
Soo got around to installing the fuel pump/surge tank today. Took a bit of convincing but I managed to get it in :D I used USRT's wiring harness which made this alot simpler!
Its a quality piece of kit
http://www.vwwatercooled.com.au/foru...05e5fa30-1.jpg
Had to modify the stock intercooler bracket a little to mount the pump, but is nice and solid now
http://www.vwwatercooled.com.au/foru...75d65aaf-1.jpg
how it sits
http://www.vwwatercooled.com.au/foru...6d365a14-1.jpg
I ran the tank feed and return lines along the fender, under the evap and washer reservoir to try and minimise clutter. I think it turned out quite neat
http://www.vwwatercooled.com.au/foru...6613fe62-1.jpg
So after I got all the leaks sorted I took it for a test drive. It's um, pretty loud hey. Not unbearable but definitely noticeable but this setup is good for over 500hp.
Sexy looking thing that!! AFR?
