Page 16 of 53 FirstFirst ... 6141516171826 ... LastLast
Results 151 to 160 of 529
Thread: Lito's MK4 GTI
  1. #151
    Done a bit this afternoon after tea.
    Rods built up
    First one in after also checking ring gaps
    And the rest
    Rods bolts torqued up the required 3 times to 50lbft
    The sump is now on. It's a spare as the drain plug was stripped in Lito's.
    Tomorrow morning I'll be doing the belt and water pump, as well as dropping the head back on.
  2. #152
    brisbane
    Nice work fellas, moving fast, keen to see this finished and hope it will restore my enthusiasm to get mine sorted.
    Meeting the missus in town for lunch tomorrow lito so will call in and see if you are around,
    And keep the updates coming!
  3. #153
    brisbane
    Also just remembered about this, appears you have bigger fish to fry at the moment but if you still want to do it I can give you hand. Reckon we could have it done in about a an hour
    Originally Posted by Lito
    car's looking awesome bro, im loving the new wheels. i just saw what you did to your instrument cluster, it looks great any chance you'd be willing to lend me a hand to do mine like that?? ill make it worth your while
  4. #154
    Sep 2009
    brisbane
    Quote Originally Posted by guile View Post
    hey mate, good to finally meet you the other day. still keen to do the cluster rings. ill let you know when i order them. wish i could see gavins photos but my stupid phone won't display them for some reason. oh well i should be dropping by this afternoon anyway
  5. #155
    Jan 2011
    Rooty Hill, Sydney
    Rods built up
    Hey mate just wanna know, how did you replace the rods ?
    Kay
    Garage:
    VR6
    XR6
    R36
  6. #156
    Quote Originally Posted by KKK VR6 View Post
    Kay
    You take out one of the circlips holding in the wrist/gudgeon pin. Then you can push the pin out from the other side. Lube up the little end of the new rod and push the pin back through. Reinstall the circlip. Easy.
    Watch where you put the notches for the big end bearings, they need to be on the inlet side of the piston.
    I checked the end gaps on all the rings for all the pistons, before fitting them on the rods and installing them in the block.
    You should check the big end clearances too with plastigauge but as we were using standard sized bearings and there's hundreds of these rod in existence, I didn't bother doing this.
    There's a good 1.8T rod install on youtube in 5 parts.
    Hunt down my number and call me if you like. Anytime in business hours is ok.
  7. #157
    Awesome progress Lito and Gavin. The new rods are H.U.G.E compared to the stock ones. Im sure these will be up to the task of supporting a good dose of boost from the new turbo.
  8. #158
    Sep 2009
    brisbane
    just a quick update from last night. turbo is bolted down and oil and coolant lines are being routed. intercooler piping will go back on with some modification as will the dump pipe
    had to fettle with some heater hoses to get the tip to fit but all good now. all i can say is that it's snug in there but should look like it was meant to be there once it's all back together. here's a few pics...
  9. #159
    May 2009
    Lito's MK4 GTI
    Gavin linked me to this thread.
    Good to see more 1.8T 20V going BT.
    I might have seen your car around Beaudesert Road near Algester. You live anywhere near? I'm close to Richard(guile).
    Danny
    ============================> http://www.facebook.com/EuroCarModsAus <============================
  10. #160
    Sep 2009
    brisbane
    Quote Originally Posted by cylinderhead View Post
    Danny
    yeah mate you probably have seen me around, i live in sunnybank. ill try and keep an eye out for you. what do you drive?
