Page 14 of 53 FirstFirst ... 4121314151624 ... LastLast
Results 131 to 140 of 529
Thread: Lito's MK4 GTI
  1. #131
    Sep 2009
    brisbane
    Quote Originally Posted by Deadpool View Post
    The Sticker bombing looks great. Going to do the inside of the hood or anything like that?
    cheers mate, I used to have both engine covers sticker bombed but the heat destroyed the stickers
  2. #132
    Quote Originally Posted by Lito View Post
    Wow that looks terrific. Did you coat it in heat protector or give it a gloss coat? Would that have helped at all without ruining the surface?
  3. #133
    Sep 2009
    brisbane
    I did clear coat it but the actually glue on the stickers is what came loose, If i were to do it again i would spray glue before putting the stickers on
  4. #134
    Sep 2009
    brisbane
    Moar rods arrived today,these ones actually fit
    I also received this
    I originally ordered it because my car had been over boosting then misfiring lately. Turned out the pressure source to the n75 was kinked new line and boost is as smooth and stable as ever . I'll keep this for the gt2871r install just in case it spikes but I doubt I'll need it. It'll up for sale cheap if I dont need it
    And just incase anybody is wondering the difference between the rod sizes. The 20mm are on the right
  5. #135
    brisbane
    Hey mate, noticed mine spiked at 28 the other day and yet to talk to Gav about it, sounds like I might need to talk to you too. Let me know if you end up using this or not. Cheers and all the best with the build
  6. #136
    Sep 2009
    brisbane
    Quote Originally Posted by guile View Post
    I'd double check the n75 lines for leaks, that hose has split on me a few times and I had to keep trimming it until it got so short that it kinked.
  7. #137
    Sep 2009
    brisbane
    Decided to sticker bomb the front badge today
  8. #138
    Jan 2011
    Rooty Hill, Sydney
    Loving every bit !!
    Looks sick too
    Just wondering with the rods you got, do they tell you what torque, to torque the rod bolts down to ?
    Thanks
    Kay
    Garage:
    VR6
    XR6
    R36
  9. #139
    Sep 2009
    brisbane
    Quote Originally Posted by KKK VR6 View Post
    Loving every bit !!
    Looks sick too
    Thanks
    Kay
    Thanks mate. Yeah the rods come with a little booklet. It says that the preffered method of tightening the rods is with a stretch gauge and they need to be tightened to 0.006" of stretch. It also states that if you dont have access to a stretch gauge to use a high quality torque wrench and tighten to 50ft/lbs 3 times per bolt using there supplied lubricant
  10. #140
    Torque wrench for us then.
