Page 12 of 53 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 529
Thread: Lito's MK4 GTI
  1. #111
    Sep 2009
    brisbane
    turbo clocking, should be easy, nekminut
    any suggestions on getting the bolt out?
  2. #112
    Drill and easy out. What's the bolt made of? Is it plain looking steel. I nearly said leave that until we get it ready to go on..... Doh!
  3. #113
    brisbane
    bugger, take your time and speaking from experience (i.e. i'm not a mechanic) i would drill the centre to allow the largest dia. easi-out you can use. i have used the really small ones before and snapped them off in the bolt, you really don;t want that to happen...
    and damn you i now want a bigger turbo also
  4. #114
    Sep 2009
    brisbane
    guess i was to eager, whoops . im not sure if i should have a crack at it. might just leave it for you to do if that's okay the bolt seems to be made of a very soft steel probably to protect the threads of the aluminium housing
  5. #115
    Quote Originally Posted by guile View Post
    Is there anything sticking out the back to grab with some grips. I have found in the past that drilling through generates enough heat to loosen bolts off.
    Richard is right though. The largest diameter easy out is the one to use. Snap On have some that are parallel rather than tapered, they seem to work ok in aviation.
    Don't kill yourself to get it out, we can do that when the time is right.
  6. #116
    Sep 2009
    brisbane
    what do people think about heat wrapping/ coating the manifold? also looking at getting one of these..
    http://item.mobileweb.ebay.com.au/vi...d=400333865257 necessary?
  7. #117
    Sep 2009
    brisbane
    had a crack at wrapping the manifold, i think it turned out okay...
  8. #118
    brisbane
    Sep 2009
    brisbane
    neat job, i guess thats to help with heat soak?
    well the theory is that it keeps the heat inside the manifold which helps the exhaust gases flow faster. plus will help keep the compressor housing and wastegate actuator cooler
  10. #120
    Jan 2009
    brisbane queensland
    Lito's MK4 GTI
    Just be careful with heat wrap it can wreck the parts it is on and you have to replace it every few years as it disintegrates after a while
    YAY I got my R!!!! White, recaro seats, 19" wheels, bluetooth, reverse camera
