and so i finally got round to getting it re-flashed with a different tune.
went for Custom Code this time. Camden Gti (golf loon) loaded it for me just last week. They don't need to install any chip of any sort onto your ecu so that's a definite bonus. Am very happy with it, feels great to drive.
Put it on the dyno after about 5 days.
I was getting runs of between 110-117kw (seemed to increase with each run, strange for a turbo).
I tried both the N75J valve and the stock N75 valve. They didn't seem to make a difference looking at the results.
The last run gave the highest peak output (so much for heatsoak, suppose because it was cold...)
All runs had an AFR consistantly below 11:1, so a lot richer than you'd hope, but it seems to still make the power it should be making. Just hopefully in summer with hotter intake temps it doesn't go to the ****! Time will tell.
Boosting a bit higher than it probably should too. Hit 20psi on every run. Though on the road it seems to be more 15-18. Feels great though having all that torque.
Check out all the area under the curve!
