Results 11 to 20 of 31
Thread: Jits MK4 GTI
    Feb 2007
    Looking very cool mate, nice seeing a red one too! Not many around.
    Mk3.Mk4.Mk1
    My Mk1 Project
    Jun 2014
    Canberra
    Quote Originally Posted by madglf3 View Post
    Cheers man. Yeah I've only seen 2 around in my locality so far
    Nov 2012
    Melbourne, VIC
    Looking good man! How does the swaybar go at that height? Any rubbing?
    Jun 2014
    Canberra
    Quote Originally Posted by SLAJ View Post
    No rubbing at all man. Plenty of clearance
    Jun 2014
    Canberra
    Necessary mod
    Jan 2014
    Narangba QLD
    i need to do that ^^
    does the r32 bar go under the driveshafts ??
    where did you get it from? bolts on straight up?
    Munno Para West Adelaide
    Whats the benefits of having the r32 sway bar rather than the usualy fwd bars?
    Jan 2014
    Narangba QLD
    The standard bar goes over the shaft and rubs when you go lower. The r32 one goes underneath by the look and hence no rubbing
    Quote Originally Posted by dubster99 View Post
    Quote Originally Posted by blackers10 View Post
    This, is out of the way
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jun 2014
    Canberra
    Yep, assumed the correct answer to your own question haha.
    I got mine off ecs. It doesn't bolt on straight to the end links as the r32 sway bar is shorter than the OEM gti one. If you scroll above you can see how I connected them, but I do plan to get adjustable end links some time soon
