Page 19 of 20 FirstFirst ... 917181920 LastLast
Results 181 to 190 of 197
Thread: fuzion’s Audi S3 (LOBA)
  1. #181
    Jun 2008
    melbourne
    Great shot.....
    White Scirocco R
    White MK3 Golf 2dr
    White Caddy (Work Van)
  2. #182
    Oct 2006
    Quote Originally Posted by Silver dub View Post
    Great shot.....
    Thanks mate!
    We will be down with the mk6 for DOVW hopefully as well this year, S3 will rest. .maybe!
  3. #183
    Oct 2006
    35mm test shot from other night
  4. #184
    Mar 2012
    Cronulla, NSW
    Quote Originally Posted by fuzion View Post
    No updates at present.
    The LOBA LO400 Turbo will go in hopefully within the next couple weeks. Arthur @ Exoticars[/b] will hopefully get it all sorted with another new tune from GIAC to suit and other misc parts needed.
    Oh my, that is a very nice looking car.
    Current Ride: Golf GTI Mk7 MY2014|DSG|Carbon Steel
    Previous Ride: Polo GTI MY2012|DSG|RNS510|Shadow Blue|Lenso GF7 18” rims
    Instagram: @lemonskin
  5. #185
    Oct 2006
    Sorry no updates!
    Car should go into shop with a few other "things" being done at the same time in a week hopefully
    Took a few shots on the weekend, didnt come out well though but here they are;
    and
  6. #186
    Oct 2006
    So i finally bit the bullet after a lot of low balling offers for the LO400 decided, meh put it in. Along with this i had my gearbox modified with a spigot bearing/extended shaft to lessen the play/movement through the clutch (SMF) and hopefully allow smoother/quicker changes especially at higher revs (5-7k), which in turn should benefit the turbo hopefully a little as well. I did notice much less vibration throughout the car since doing this as i do have the VWR mounts in (quite sometime now). New SMF LOBA Kit in to make sure everything is 100%.
    Other things were also done, wheels came off and got soda blasted & repainted. Major service+timing service, rear calipers finally painted (professionally), and a list of other bits and pieces of 'refreshers' you could say as i like to make sure the car is spot on.
    Car feels good, haven't had it for long and we haven't got any results. Will give it a little to run in and adapt properly and i will give it back to Arthur to run some more logs, dyno it and go from there. Power wise who knows i would say from 210-to pushing my luck to 230? - however i do say 230 as Marcus with his K04-Hybrid and his S3 made 231 @ all four wheels in the recent months. But who knows! Power is much more linear and continues right up throughout the rev range, and also sounds very different on boost (induction/spool noise).
    Will try get results soon so can see what these actually do and do not make for kw & torque figures.
    That is it, no more for the car. May consider to sell it next year as well, who knows!
    super high quality iphone picture.
    Couple pictures, but not many. I couldn't be bothered to take any for once.
    So to make sense of what is done;
    LOBA LO400 + RS4 Injectors Fitted
    GIAC Tune to suit
    R&R Gearbox + LOBA SMF Clutch Kit + custom spigot bearing/and extended shaft which in turn allows quicker shifting at higher rpm and less movement (Sam was the first to do this with his MK6 GTI).
    Forge Throttle Body Hose fitted
    Neuspeed Intercooler / Pancake Pipes fitted
    BBS CK's got soda blasted, few nicks repaired and repainted.
    Intake Manifold cleaned again (Refer to other thread)
    Major Service+timing service
    Rear calipers FINALLY painted to match. (yes.... with plastidippp........)
    And other things and pieces were done and i also installed a front & rear dash cam (FineVU CRHD500 front and BlackVue for rear)
    Big thanks to Arthur @ Exoticars for organising, the GIAC tune, and also getting it altogether. Even though the car lived there lol, but that is the game we play. Tuning/Modifications.
  7. #187
    Aug 2006
    Melbourne VIC
    Time to run in down the 1/4 and around a racetrack.
  8. #188
    Need to go for a drive in one of your cars one day Pierre, you put together some cool stuff!
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  9. #189
    Jun 2008
    melbourne
    Don't do it Dylan, he's a mad man.
    White Scirocco R
    White MK3 Golf 2dr
  10. #190
    Oct 2006
    I will try to bring it down next year for DOVW but as the wedding is on month prior and away in December i don't like my chances!
    Come in May for nationals as it may look a bit different then, and maybe gone soon too who knows
