Results 1 to 4 of 4
Thread: Evil R32
    May 2013
    sydney
    Evil R32
    Engine
    ABT / RUF Supercharger 7psi boost
    Water to Air charge cooler
    Audi TT Injectors
    550NM Clutch pack
    Strengthened clutch cage
    Custom DSG software and tune
    Modified transfer case - Modified +jungle juice fluids
    Capristo 3 mode exhaust
    Mishimoto Oil cooler
    Weistec AMG Air / Oil seperator
    Handling
    Wheels - ADV, GTC, VMR etc
    Porsche 996 TT brakes
    AMG Drilled discs - Front
    Neuspeed slotted discs - Rear
    H&R sway bars – Front & Rear
    Vogtland Coilovers – Height & Damper adjust
    Solid engine mounts – VF Engineering side, gearbox and pendulum
    Nolathane bushings – Control arm, Trailing arm & steering rack
    Golf MKVI Steering rack
    Whiteline Anti-lift Kit
    Haldex GEN 2 Blue Controller & Switch
    UNIBRACE Underbody
    UNIBRACE Stressbrace
    Aesthetics
    Carbon and Alcantara interior
    P3 Vent Guage
    Blacked out VW badges – Front & Rear
    OSIR Carbon Valence
    LED interior lights
    RNS 510
    11 Inch Focal sub & Amp – Custom molding
    Custom illuminated gadget stash in armrest
    OEM Smoked LED Tails – US Spec, Fog delete + quad ring mod
    LED Plate lights
    Black Aluminium A/C bezels
    Blue R36 Coil pack covers
    Carstyle4U Switches - Eject + Tacks
    Smoked mirror indicator lenses
    OSIR Carbon grill + Custom R32 inserts
    OSIR Carbon wing
    OSIR Interior stripe
    Custom DSG Tune
    Pos - DSG adjustment - Mode
    1 torque limit increase to 550Nm
    2 Increase of automatic up shifting - NO - Manual
    3 Deactivation of automatic up shifting - Manual - Note: Rev Limit will be reached
    4 Deactivation of Kick down - Manual
    5 Increase Launch Control - 4250 RPM - LC
    6 Shift time - Shortest possible 50ms (Up to) - D, S and M
    7 Increase of max rev limit +1000 RPM
    8 Increase of max revs at down shifting
    9 Adjustment of shift points D and S
    10 Adjustment of start up regulators - D, S and M - For reinforced clutches
    11 Adjustment of start up torque - D, S and M
    12 Adjustment of gear change timing - D, S and M
    Apr 2012
    Bridgeman Downs ,Brisbane
    daaayymmm !!!!!! this is tooo good
    NSW, Sydney
    Yes, you finally made a build thread for this beast on here Adam!
    The pictures above of this car does not show it justice until you look at this masterpiece in person and recognise the amount of hard work and money that has been put in from the get-go. Is there any reason the back of the car sits higher than the front? Been wanting to ask you for a long time, just haven't got around to it. Keen to see photos, specially that interior with all the carbon fibre parts.
    Well done
    May 2013
    WOW that's nuts
