Results 1 to 10 of 10
Thread: avatars
mk14wd avatars 15-06-2006, 11:13 AM
Tim it looks as tho the avatar... 15-06-2006, 12:48 PM
mk14wd ive noticed that brackies one... 15-06-2006, 12:59 PM
Guest Enabled 15-06-2006, 01:01 PM
worm testing one two three 15-06-2006, 01:14 PM
mk14wd my edit avatar link has... 15-06-2006, 01:18 PM
    avatars
    howcome they dont work anymore?
    78 Mk1 Golf
    62 beetle still 6 volts
    Point Cook, Vic
    it looks as tho the avatar option is disabled at the moment.
    ive noticed that brackies one works still
    78 Mk1 Golf
    brackie Guest
    Enabled
    Yes, they're enabled. It's hard when you're logged on as an administrator 'cos very often you don't see what everybody else sees! I looked straight into it and all avatar options are enabled. There shouldn't be a problem (having said that I had to re-upload my own avatar). So I'll log on with an alias and see what happens.
    Dec 2005
    my
    edit avatar
    link has dissapeared all together
    maybe im looking in the wrong place?
    78 Mk1 Golf
    Dec 2005
    Im not sure what the problem is, but when you goto "User CP" which is the user control panel the avatars and smilies are OFF but when you post a reply it says the are ON... so im thinking that the OFF in the User CP needs to be turned on *shrugs*
Similar Threads
  1. avatars
    By Rednut in forum User tips and Forum Suggestions
    Last Post: 12-02-2007, 01:05 PM
