Results 1 to 10 of 27
Thread: You Guys are going to hate me..
smithy010 You Guys are going to hate... 07-06-2008, 06:59 PM
Jarred Nice one. Don't worry not all... 07-06-2008, 07:06 PM
smithy010 stop press.. 07-06-2008, 08:03 PM
Jarred glad to see you actuallly... 07-06-2008, 08:33 PM
gregozedobe Hey, as long as you like it... 07-06-2008, 09:41 PM
smithy010 If there is a pug forum, i'm... 07-06-2008, 09:48 PM
Soundofav6 We are not going to hate you.... 07-06-2008, 10:01 PM
Mrk_Mickey My mate's got an awesome... 07-06-2008, 11:58 PM
The_Hawk Remeber its very much like a... 08-06-2008, 09:50 AM
gldgti ahh, the peugeot. i know a... 08-06-2008, 10:46 AM
smithy010 Actually, the HDI engines... 08-06-2008, 12:49 PM
gldgti ahhh, there ya go. well then,... 08-06-2008, 12:54 PM
smithy010 It's already got one :) It... 08-06-2008, 01:10 PM
cetane Please don't ban Smithy! 09-06-2008, 07:29 AM
smithy010 Don't worry about that. I... 09-06-2008, 10:01 AM
evorobin My dad has a 306TDI too. My... 09-06-2008, 10:40 AM
smithy010 Well it will certainly be... 09-06-2008, 01:16 PM
smithy010 Well, i picked it up... 11-06-2008, 07:55 AM
cetane Turbo lag 11-06-2008, 05:42 PM
Golf Loon That sounds like a bargain... 11-06-2008, 06:42 PM
smithy010 Thanks for the encouragement... 12-06-2008, 09:42 PM
smithy010 Well, i've been doing some... 19-06-2008, 08:04 AM
cetane Glow plugs. 19-06-2008, 12:21 PM
gldgti some of the early 1.5's had... 19-06-2008, 10:12 PM
Volvo Driver There's a bloke at trade... 23-06-2008, 09:47 PM
smithy010 I've been reading a little... 25-06-2008, 08:15 AM
gldgti highly likely that your pug... 02-07-2008, 05:14 PM
    May 2006
    Maroubra NSW
    Well, i've been doing some ironing out on the pug.. First i bled the cooling system, which stopped it from pressurising (i was scared before that, could've easily been a head gasket)..
    Following that, i removed the door cards and started diagnosing the problem with the LHS Electric window and mirror. Turns out i have traced it to a broken wire where it goes from the body to the drivers side door (wires must've fatigued).
    FYI, the engine in this vehicle is an indirect injected intercooled turbo diesel engine. Too bad it doesn't have the bosch VE pump.. Instead, it's got a lucas. Anyone know about the lucas pump as far as tuning goes?
    I like the fact that it's got less electronic bits than the TDI.. There's enough crap on it already let alone having electronics on the engine as well..
    Next Job: PUll the glowplugs and test them, so i can iron out a little Cold starting problem.. At the moment it cranks for about 5 seconds after a 15 second glow, then it will fire, and run on 2 cylinders, then about 3 seconds later it will fire on all 4. If it's not the plugs, then it's probably compression..
    All in all, though, for a car with so many k's, i reckon it's doing pretty well, and it's a pleasure to drive. It's great to give it a little squirt now and then on the way to work. The real power band (as Aydan said, with the IDI it is a bit higher) is about 2500 to 3500..
    Please tell me if i should shut up about non VAG cars.. ok?
    Peugeot 306 XTDT 1.9 Turbo Intercooled Diesel
    1976 LS parts vehicle
    Used to have: Mk1 Swallowtail LS DIESEL!
    Nov 2007
    The Land of Oz
    Glow plugs.
    Hey, Smithy... Don't worry. It's great that you haven't forgotten us!
    My guess is that the starting problem is glow plugs. A quick way of testing them in situ is with a multimeter or test lamp. Take off the bus bar and you should have virtually no resistance through the glow plug. Test them all and suspect the ones with high resistance.... or if they're open circuit chuck 'em away. ebay UK is good source of replacements.
    There's nothing wrong with Lucas ips. Lucas and CAV used to jointly manufacture them. My 1964 Inter tractor has a Lucas ip and it's done 12,000hrs without a problem. It doesn't evern leak when using ULSD.
    Gosford Central Coast NSW
    some of the early 1.5's had CAV pumps...
    correct me if i'm wrong, but i think they might even have similar external mounting points? not sure about that one.
    IDI is good for you, it means your 100% bio compatible still, and no electronics to annoy you in fault diagnosis should you get into tgrouble.
    well, theres just a few things for you to do then - read up on how strong the pug diesels are, and get the boost and fuelling sorted! heheheheee. i know im a sick puppy.
    anyway, like has been mentioned, definateyl just start with your glowplugs - very likely. after that the injection timing might be worth checking - not enough advance really hurts the cold starting.
    good luck
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Melbourne, Australia
    There's a bloke at trade school who owns a 01 306 HDI, and we gets better economy then Dad's Mk3 does, which i a bit dismal lately IMO, only 500km's or so out of 30 litres.
    But our 307 has that sort of high RPM powerband compared to the TDi in the Golf.
    88' Volvo 760GLE
    88' Volvo 740 Turbo
    Quote Originally Posted by tosspot View Post
    Also, drags are the worst form of motorsport. Who'd want a fast drag car for their street car?
    May 2006
    Maroubra NSW
    I've been reading a little bit about tuning the pug turbo diesel engine.
    There are rumours (unconfirmed as yet), that the XUD9TE engine was detuned in the factory so that it didn't beat the ass off the sports model that was out in those days.. So apparently it's a piece of piss to up the fuelling and adjust the wastegate up to 19psi with no problems. The only little thing that pisses me off is that you have to drain the IP every time you want to adjust the smoke screw because it is actually INSIDE the lucas pump, which is a real pita. No "dynamic" tuning for this pump!
    Anyway, before i do any tuning, i want to make extra sure that i've got no problems. I'm thinking a compression and leakdown test will be the order of the day, followed closely by an injector test.
    highly likely that your pug has been factory detuned - see VW/audi diesels from 1985-onwards and their "rpm governors" (read: "fun governors").
    get that thing hauling mate!
    '99 A4 Quattro 1.8T
