Results 1 to 4 of 4
Thread: Yeti tdi fuel tank leak?
    Apr 2016
    Hi I'm a newbie, bought a 2011 tdi yeti with 90k on it tm2 months ago. Apart from needing timing belt change the car is going great. However thus morning I noticed some diesel on the carport floor under drivers side of fuel tank. Any advice about common issues.
    Sent from my SM-G920I using Tapatalk
    Feb 2014
    Central Vic
    Had you recently topped it 'right up' and started a small leak down the overfill pipe which spills near your feet?.
    How big is the leak?.....a small quantity makes a big impression given time.
    Check tighten the hose clamp perhaps.
    Gosford Central Coast NSW
    Quote Originally Posted by stevarm42 View Post
    No common issues I would say.
    If you had just recently filled it up, on a really cold night, and then this cloudy weather came over and it expanded, a little could have drained from the expansion overflow perhaps.
    Otherwise you'd be best served having a good look around to see if you can spot any areas that look suspect.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Apr 2016
    Thanks its good to know its not a common issue. I'll put it on stands and have a closer look around (once the east coast low passes).
