Results 1 to 10 of 12
Thread: Won't start
    Jul 2010
    Robina Gold Coast
    Won't start
    Today it happened again, this is the third time in two years where the car just wont start, Had to crank the Engine for over a minute before there was any sign of it starting and when it did it took a while for all cylinders to fire up , but once started it will start easy all day,
    I used the car on Sunday and it was OK , so now 4 days latter it refuses , plenty of fuel , the oil message came up while i was attempting to start mainly because the starter motor was going constantly.
    Adelaide hills, SA
    What car? You need to post some car details, if you want people to respond.
    Jul 2010
    Robina Gold Coast
    Sorry Transporter Its a 2008/09 2.00 ltr GT diesel sports with 48,000km on the clock ,it only happens once in a while all other times it starts ok .
    Adelaide hills, SA
    It could be the check valve on in intank fuel pump. You could fit the clear tubing in the fuel line at the fuel filter to check for air in the fuel. Of course it could be many other things as well. How old is the battery? Get the battery tested if in doubts, some places where they're selling the batteries will do it for you for free.
    Was the fuel filter replaced yet?
    Dec 2008
    Sydney/Canberra
    Check the battery voltage, and also check the engine speed while cranking.
    The injectors will not squirt at anything less than 280rpm.
    If the battery is ok, but the cranking speed is less than 280rpm, it may need a starter motor.
    As always, have the vehicle diagnosed by your preferred repairer. There's only so much that can be achieved over the internet.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    May 2009
    Frankston, Vic
    Same thing happened to me tonight (08 Passat 2.0TDI 125kw), happened for so long I ended up calling RACV because I thought it needed to be towed, didn't throw any codes.
    He just kept hammering the ignition and it eventually started, went for a thrash, filled her up with some fresh fuel and she's running good as new again. ****ed if I know what was wrong....I just hope it doesn't get worse/happen again, driving to Adelaide on Friday and I'd rather not get stuck somewhere along the Western Highway.
    Mar 2009
    Brisvegas
    Quote Originally Posted by manol View Post
    So my '95 TDI auto is doing the no-start as well. Owned it three days, all good first day, did 140 kays mostly freeway, slight hesitation once on day two another 30 kays all good lots of stop-start, but morning of day three no-start.
    Well, it does start and runs just long enough to get up to 800-900 RPM, then dies.
    Wont start at all for a while, but if left it repeats the cycle. Fuel and oil and battery all seem good, recent service.
    It does have a turbo timer, but I think I have turned it off.
    And, yes, I have left a message with Jimmy, altho at the time it wasn't for this
    Any clues welcome.
    MY09 Golf Candy White 2.0 TDI Pacific
    MY95 Golf III TDI
    Nov 2005
    Sydney NSW
    glow plugs? if there is a faulty one it can affect the start - even without throwing a code.
    My Mk3 would not start 3 weeks ago for 3 days even in the warming 18deg afternoon unless I kept on the ignition... finally started rough for 20 secs then comes good... lots of smoke on start and sounds like there is air in the fuel line but once it was going it seemed fine.
    Took it to the mechanics as the TDI Timing was Too advanced for VCDS TDI TIming Checker... tuns out that the glow plugs died, car started fine after they put in new glow plugs for 3 days at the shop but the timing was still too advanced for their liking... turns out a timing belt pully was wearing its bearing and it threw the timing off by 1/2 a tooth... All sorted now and next to no smoke out the back for my Little Red Sooty.
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
    Gosford Central Coast NSW
    that sounds like air in the fuel line.
    Quote Originally Posted by yowie View Post
    Any clues welcome.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Mar 2009
    Brisvegas
    Arrrgh!
    Seems its an intermittent, love that word, fault with the after-market turbo timer.
    Which will now be removed unless people think they are worth replacing.
    The RACQ guy started it first go, which should probably read, it put its best manners in for the mechanic.
    I wasn't home, so not sure about details.
    But I drove it just now, gamely parked and re-started, and no worries.
    Thanks for the considered opinions.
    MY95 Golf III TDI
