After owning our new 2007 Skoda Octavia 1.9TDI for nearly 3 weeks, I thought I would do a bit of a service on her to make sure everything was ok and to familiarise myself with the car a bit more. I've always been hands on with all my cars and this is no different, only its the newest car I've owned by far.
So, the lineup of jobs to do was:
> Oil and filter change
> Air filter inspection/change
> Fuel filter inspection/change
> General look around
> Install Mann&Hummel PROVENT 200
Things you'll need when working on your 1z octavia, or indeed mk5 golf, 9n polo, etc....
> 1/2" and 1/4" socket set
> torx screwdrivers or torx bit, all sizes
> basic screwdriver set
> decent trolley jack
> axel stands
> oil drop pan
> various "garage supplies" like rags, newspaper, beer.
You can use ramps, but because I was doing more of a general inspection (and I wanted to look over the suspension, etc) I supported the car on axle stands, with the car supported under the rear wishbone bushings on the front subframe.
1) Use torx drivers to remove the smaller screws (4 on each side) holding the plastic undertray to the bodywork.
2) Support the weight of the undertray and remove the 3 larger torx bolts towards the rear of the tray. Slide the tray rearward so that it is released from the front splitter and remove the tray from under the car.
3) Now we can see the underside of the engine bay and access the oil sump.
We can see that the octavia has a front mounted intercooler, which resides in between the radiator and a/c condensor. Its HUGE - and a good thing to, its a pretty big car for this engine, and a tiny turbo!
Heres a pic of the tiny little VNT-15. This turbo really is small, I kinda want it to fail so I can put a proper turbo in there and get some real power.
and the cat integrated into the downpipe.... not a DPF, but you can see they put it nice and close to the turbo so that it gets hot fast and burns out any soot.
the O2A gearbox that we know and love - this is actually exactly the same gearbox I had in my mk3
4) Drain the oil
5) Use a 32mm socket, long extension and ratchet to remove the oil filter housing. Be careful with it, it can be broken if you are too enthusiastic.
6) Replace the filter with a new one. It just unclips (pulls) out. The new filter will just clip in place.
7) Replace the big O-ring seal. Prise it out with a small, blunt flat bladed screwdriver. Before you put the new one in, lubricate it with some clean engine oil.
